2nd ring gap (potential) issue
#2100771
06/29/16 10:14 PM
06/29/16 10:14 PM
RapidRobert
30 over race only 360 with KB hypers. 5/64 moly top/cast 2nd. my measured 2nd ring gap is .028". will this hurt my power greatly (or so so) or am I OK as is? I could spring for another set if I need to. thank you for your time.
Re: 2nd ring gap (potential) issue
[Re: RapidRobert]
#2100786
06/29/16 10:34 PM
06/29/16 10:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run the second ring gap bigger that the top.. if it got by the top you dont want to hold it in the second and cause flutter
[Re: MR_P_BODY]
#2100840
06/29/16 11:35 PM
06/29/16 11:35 PM
Posts: 4,457 Washington
madscientist
Washington
I run the second ring gap bigger that the top.. if it got by the top you dont want to hold it in the second and cause flutter ^^^^^^^^^^^This^^^^^^^^^^^^^
[Re: cudaman1969]
#2100865
06/30/16 12:17 AM
06/30/16 12:17 AM
RapidRobert
Sounds unanimous! I'll start going together tomorrow. Thanks guys
[Re: cudaman1969]
#2100906
06/30/16 01:13 AM
06/30/16 01:13 AM
madscientist
Washington
C&A told me to run the gapless on the second ring and the reg one at the top Different set of rings.
[Re: cudaman1969]
#2100933
06/30/16 01:51 AM
06/30/16 01:51 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
C&A told me to run the gapless on the second ring and the reg one at the top How many years ago was that OP, .028 end gap on the second will work fine
[Re: RapidRobert]
#2101076
06/30/16 12:42 PM
06/30/16 12:42 PM
Thumperdart
State of confusion
The new trend for some are a wider 2nd ring and mine have been that way for years.......
