2nd ring gap (potential) issue #2100771
06/29/16 10:14 PM
06/29/16 10:14 PM
RapidRobert Offline OP
30 over race only 360 with KB hypers. 5/64 moly top/cast 2nd. my measured 2nd ring gap is .028". will this hurt my power greatly (or so so) or am I OK as is? I could spring for another set if I need to. thank you for your time.
Re: 2nd ring gap (potential) issue [Re: RapidRobert] #2100781
06/29/16 10:28 PM
06/29/16 10:28 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I would run it.
Re: 2nd ring gap (potential) issue [Re: RapidRobert] #2100784
06/29/16 10:31 PM
06/29/16 10:31 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
iagree
Re: 2nd ring gap (potential) issue [Re: Leon441] #2100785
06/29/16 10:34 PM
06/29/16 10:34 PM
gregsdart Offline
gregsdart  Offline
Originally Posted By Leon441
I would run it.
yep
Re: 2nd ring gap (potential) issue [Re: RapidRobert] #2100786
06/29/16 10:34 PM
06/29/16 10:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the second ring gap bigger that the top..
if it got by the top you dont want to hold it in
the second and cause flutter
wave
Re: 2nd ring gap (potential) issue [Re: MR_P_BODY] #2100840
06/29/16 11:35 PM
06/29/16 11:35 PM
Washington
madscientist Offline
Washington
wave
^^^^^^^^^^^This^^^^^^^^^^^^^
Re: 2nd ring gap (potential) issue [Re: RapidRobert] #2100859
06/30/16 12:09 AM
06/30/16 12:09 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
C&A told me to run the gapless on the second ring and the reg one at the top
Re: 2nd ring gap (potential) issue [Re: cudaman1969] #2100865
06/30/16 12:17 AM
06/30/16 12:17 AM
Sounds unanimous! I'll start going together tomorrow. Thanks guys
Re: 2nd ring gap (potential) issue [Re: cudaman1969] #2100906
06/30/16 01:13 AM
06/30/16 01:13 AM
Washington
Washington
Different set of rings.
Re: 2nd ring gap (potential) issue [Re: cudaman1969] #2100933
06/30/16 01:51 AM
06/30/16 01:51 AM
Cab_Burge Online work
Cab_Burge  Online Work
How many years ago was that work
OP, .028 end gap on the second will work fine thumbs
Re: 2nd ring gap (potential) issue [Re: RapidRobert] #2100964
06/30/16 06:00 AM
06/30/16 06:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree that sounds fine. They are hypers as I know they call for a larger gap on the top ring then cast or forged pistons so just be sure and set the gaps at least as wide as the specs call for. I have run a few older worn engines with wider gaps and had no problems at all. Better to be a tad wide then to small of a ring gap. Ron
Re: 2nd ring gap (potential) issue [Re: RapidRobert] #2101076
06/30/16 12:42 PM
06/30/16 12:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The new trend for some are a wider 2nd ring and mine have been that way for years.......
