What components/hardware from 7 1/4 can be trans. to 8 3/4?
#2100991
06/30/16 09:46 AM
06/30/16 09:46 AM
Posts: 1,565 Macomb, MI
vinnyd76
Macomb, MI
I have a 7 1/4 rear axle out of a 70 A-Body. What components/hardware from the 7 1/4 axle assembly can be transferred to 8 3/4? The 7 1/4 rear axle has 9-inch drums and the 8 3/4 will have 10-inch drums, so the drums and shoes will out along with backing plates. Axle half shafts? U-bolts that attach the leaf springs to the axle? Park brake cable?
I'm planning to stay with the 4-inch bolt pattern (drum brake setup) with the 8 3/4 axle assembly.
Thank you in advance for your feedback!
Re: What components/hardware from 7 1/4 can be trans. to 8 3/4?
[Re: Rhinodart]
#2101006
06/30/16 10:28 AM
06/30/16 10:28 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
The only thing that will interchange is the parking brake cables. What he said ... Axle tubes are larger so you need new u bolts AND shock plates and a shorter driveshaft .
[Re: Kern Dog]
#2101398
06/30/16 11:09 PM
06/30/16 11:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The gear oil interchanges. Now that's cheap. The brake lines might be made to work though.
