46re valve body interchange #2100755
06/29/16 09:39 PM
06/29/16 09:39 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Can anyone tell me if the valve body from a 1997 46re will work in a 2001 46re trans? I know the electronics are different and need to be switched. I have heard conflicting awnsers on this. One person said yes it will work and the local trans shop stated it might but the transfer plate and check balls are different so they can not be sure. Thanks
Re: 46re valve body interchange [Re: mod381] #2100765
06/29/16 10:00 PM
06/29/16 10:00 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
The 01 trans has the 3 pin safety switch and not the large box one as I read that does matter
Re: 46re valve body interchange [Re: mod381] #2100800
06/29/16 10:55 PM
06/29/16 10:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Both of them should have the eight wire plug on the drivers side also as they are both electronic gov trans. They may be the same as I dont remember if there was any running changes in them from 1997 to 2001 but basically they are the same trans. Not sure what you mean about the large box one ? Maybe you mean a 45RFE which was behind the Hemi's. If anyone knows about the 97 V/B working in the 2001 John Kunkel most likely will. You are sure both are 46RE tranny's right ? Ron
Re: 46re valve body interchange [Re: mod381] #2100807
06/29/16 10:59 PM
06/29/16 10:59 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Yes both are 46re trans. What I mean by that is around mid year 2001 and later they started to use a 5 pin neutral safety switch instead of the older 3 pin.
Re: 46re valve body interchange [Re: mod381] #2100819
06/29/16 11:13 PM
06/29/16 11:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They should both have the eight wire plug on the drivers side that points up as thats for the gov press sensor , gov solenoid , trans fluid temp , lock-up and overdrive. The only ones I remember with a 5 pin connector at the NSS instead of the 3 pin switch was the ones that used a Range Sensor for the electronic reading in the dash. But its been a long time since I worked on one and my memeory may be a little fuzzy on it. I would need to look at the wiring diagram to be sure. Ron
Re: 46re valve body interchange [Re: mod381] #2101011
06/30/16 10:39 AM
06/30/16 10:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You would need to leave whichever neutral safety switch the truck has in place.
The neutral safety is activated my the rooster comb on the valve body (the part the linkage activates and the park rod connects too) , look at the 2 of them , if they are different just swap the part needed from the original to the donor .
Re: 46re valve body interchange [Re: mod381] #2101818
07/01/16 12:32 PM
07/01/16 12:32 PM
A727Tflite Online content
A727Tflite  Online Content
The governor pressure transducer is different. The pre-2000 was a metal can type 4 pin, the 2000 and later is a plastic one with blade connector. Mix them up and you have issues - the remainder of the valve body is essentially the same - make sure you match the filter and pan - they changed over the years.
Re: 46re valve body interchange [Re: A727Tflite] #2102403
07/02/16 10:17 AM
07/02/16 10:17 AM
NJ
69 charger man Offline
NJ
Look at this web site. The valve body is slightly different mainly where the front pump area is . Some have a large or small area
http://www.sonnax.com/articles/257-chrysler-42re-46re-47re-valve-body-identification
