small block mopar reverse cooling #2100245
06/28/16 10:52 PM
06/28/16 10:52 PM
Brunswick Ohio
dusta340 Offline OP
dusta340  Offline OP
Brunswick Ohio
does any one have any insight on doing reverse cooling on a small block mopars?
my combo is 440ci, R3 48 degree block, indy 360-1 headed motor with a pt98 turbo,(1300whp) i am trying to keep the heads cooler mostly the center cylinders as it looked like the head gaskets was not very happy there after winter tear down. i have googled and can not find any real goods info on it.
side note does any one have any real world info on evans waterless coolant
thanks for the help guys
Re: small block mopar reverse cooling [Re: dusta340] #2100249
06/28/16 10:55 PM
06/28/16 10:55 PM
go to www.moparchat.com then scroll down & click on "circle track chat" then read thru Sanborns' cooling mods that are in a sticky at the top of the page.
Re: small block mopar reverse cooling [Re: dusta340] #2100314
06/29/16 12:15 AM
06/29/16 12:15 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Is it a siamese bore block? If so, is the deck, gasket and head drilled for coolant at the pinch?
