Re: 440 source heads retorque
[Re: pettyblue440]
#2100201
06/28/16 09:45 PM
06/28/16 09:45 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
aLWAYS RE TORQUE ANYTHING ALUMINUM.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: pettyblue440]
#2100255
06/28/16 11:01 PM
06/28/16 11:01 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Many on the race section have said they did not retorque their head bolts after the eng was warm. I was surprised as how many do not do it and have said they had no problems at all. Course you have to unbolt the headers on the bigblock and I guess many did not want to do it. I did retorque the Eddy heads on my sons 400 and they were all good so I did not do it on my 440/493 with EZ heads and it has been running fine with no problems since 2011. Ron
[Re: pettyblue440]
#2100351
06/29/16 01:05 AM
06/29/16 01:05 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
MY first RB rebuild, 413 iron heads, FWIW, I didn't retorque the stock shim head gaskets.
They failed, so I go to pull iron heads off and replace them, retorqued them then.
What head gasket are you running and what does the head gasket maker say?
[Re: pettyblue440]
#2100571
06/29/16 02:59 PM
06/29/16 02:59 PM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
My Stealths have been on like 5 or 6 years now.I run 12.5 domes on the street.Used FelPro marine gaskets.Never retorqued them and no problems.Same when I do all ny heads.Rocky
Chrysler Firepower
[Re: pettyblue440]
#2101061
06/30/16 12:14 PM
06/30/16 12:14 PM
therocks
Niles , Ohio
If it was all dealers would have millions to retorque.Unless you run a full race car its not necessary.But if it makes you feel good do it.Rocky
Chrysler Firepower
[Re: pettyblue440]
#2101278
06/30/16 07:58 PM
06/30/16 07:58 PM
crabman173
crabman173
I have never done it--almost always use Felpro 1009 never had an issue Work at a shop that churns engines out the door--never retq or advise customers to do it Now...I raced an LA small block for years--10 head bolts--we always ran clear hose on the evacs--when you saw vapor in the tube you better put a new gasket on before next race--we did retorque the small block race engines--did it help? who knows--with high compression and 4 bolts per hole it was simply a thing that had to be done but with big blocks no way I would waste the time---I will tell you this--if both the block and head are flat--you could almost run no gasket--but if surface prep is poor or ignored it seems to me to be the root of all head gasket issues
