My 440 was misfiring when idling. #2100113
06/28/16 07:39 PM
06/28/16 07:39 PM
mass
0
03dodgeram Offline OP
mass
My 440 is misfiring at idle. Not at the same time. Would a loss ground wire on the msd box make it misfire.Just noticed it being loss. Thanks for info
Re: My 440 was misfiring when idling. [Re: 03dodgeram] #2100161
06/28/16 08:53 PM
06/28/16 08:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just went through this.
I found a burnt spark plug wire boot.
Might not be your problem, but worth checking.
Re: My 440 was misfiring when idling. [Re: 451Mopar] #2100178
06/28/16 09:17 PM
06/28/16 09:17 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I agree...
Open the hood at night and look for sparks.. How old are the spark plugs and wires??
Re: My 440 was misfiring when idling. [Re: minivan] #2100188
06/28/16 09:29 PM
06/28/16 09:29 PM
mass
0
mass
The wires and plugs are one year old. New cap.
Re: My 440 was misfiring when idling. [Re: 03dodgeram] #2100240
06/28/16 10:48 PM
06/28/16 10:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That means nothing.
Don't be the exception.
Re: My 440 was misfiring when idling. [Re: Supercuda] #2100330
06/29/16 12:37 AM
06/29/16 12:37 AM
Tacoma, Washington USA
Adam71Charger Offline
That means nothing.
iagree
Re: My 440 was misfiring when idling. [Re: 03dodgeram] #2100347
06/29/16 01:00 AM
06/29/16 01:00 AM
pull the plugs & see if any are fouled. If you have any extra plug wires you might sub em in for a quick test. did this start all of a sudden? what did you mean "not at the same time" You might pull the carb top & clean it out and take out the idle mixture screws and blast the ports with a 3 second shot of brake kleen with the thin red straw to get in there. Keep us updated
Re: My 440 was misfiring when idling. [Re: Adam71Charger] #2100429
06/29/16 08:08 AM
06/29/16 08:08 AM
mass
0
mass
Didnt drive the car after i installed the new wires and plugs.
Re: My 440 was misfiring when idling. [Re: 03dodgeram] #2100684
06/29/16 07:05 PM
06/29/16 07:05 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Wrong firing order.. Recheck your wires ( Make sure they are on the correct plugs) and then recheck them again......
