Hi speed by pass rons injection
#2098402
06/26/16 11:01 AM
06/26/16 11:01 AM
Posts: 2,449 nc
earthmover
nc
Any of you guys have a picture or could give me a run down on your set up please..thank you in advance
At what point do you need to install 1 and where...
Re: Hi speed by pass rons injection
[Re: earthmover]
#2098443
06/26/16 12:28 PM
06/26/16 12:28 PM
Posts: 159 australia
charger410
australia
I'll post a pic and run down of my Kinsler stack injection in the morning. I would have thought in principle the same as toilet. Hi speed is to bleed off fuel as your rpm increases other wise you will run too rich. It provides control of the fuel curve.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: charger410]
#2098487
06/26/16 01:43 PM
06/26/16 01:43 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Nice looking car Charger410.
[Re: earthmover]
#2098858
06/26/16 10:54 PM
06/26/16 10:54 PM
charger410
australia
Thanks Jim👍 Here's a quick run down on how the Hi Speed works: belt driven pump off the engine, fuel volume/ pressure increases with rpm. Idle Bleed, Hi Speed both open at a set psi and then also incorporate a jet in order to bleed off fuel. An engine in this case needs a plenty of fuel up to max torque and then needs the Hi Speed to bleed off fuel. If it didn't the engine will drown in excess fuel.
[Re: earthmover]
#2098907
06/26/16 11:51 PM
06/26/16 11:51 PM
charger410
australia
Sounds like the problem is in the initial setting of the ball valve. Yes Rons will have to advise or someone who runs a toilet. It needs to be in sink with the throttle blade and only needs to be a very small amount out to throw the hole thing out.
[Re: earthmover]
#2099493
06/27/16 07:30 PM
06/27/16 07:30 PM
Posts: 70 Oregon
sccuda
If the system is set up correctly and you are using the correct parts you should not need one. I have a Billet Pump, with twin toilets, older barrel valve, no high speed. I bracket race 8.30s @ 2800lb 572 B1MC deal also Throttle stop race S/G 9.90 deal if you must use one use an electric one ( more consistant) I would talk with Scott Offerman at Killer Rons.com he can help you out. Your barrel valve should be set at around 17-28% leak down unless you are blown or boosted. This is system is deadly consistant dont over complicate it
