I need to know how to identify what type of brake hose and/or lines I need to swap from my E-body 8.75" drum rear brake setup to use the same brakes on the Strange S-60 assembly I bought from Dr. Diff in spring 2015.
I'd talked w/ Cass about this at the time I bought the S-60, but don't recall now whether he said we can match up new hard lines as long as we know what type of hose leads to the existing 8.75 brake setup, or if it's going to require replacing some hoses as well as hard lines to the brakes once they're swapped over.
Until I get the S-60 in (even if it's just rolling-capable), I can't move The MoPig around in order to drop in the engine. Right now it's up on jack stands w/ the 8.75 housing still mounted, but the 3rd member & axles are gone (sold) so it's stuck until the new diff install.
