440 Engine Missing at Higher RPM
#2099187
06/27/16 12:09 PM
06/27/16 12:09 PM
fury4speed
I have a 440 and it always ran fine , this weekend it started missing , it starts fine when cold , it started missing about have throttle / under load , it does not miss while idling , it has a Holley 800 D/P and a Mopar electronic distributor with the box on the firewall , it is now hard starting when warm / hot , cold it starts fine , I am thinking it might be a blown power valve as smoke comes out of the exhaust when it finally starts , it seems loaded up and takes a long time to finally startand has never done this before , I think it is carburetor related , it seems the more I drive it the worse it gets , any suggestions , thanks.
Re: 440 Engine Missing at Higher RPM
[Re: fury4speed]
#2099198
06/27/16 12:27 PM
06/27/16 12:27 PM
RapidRobert
I'd start by seeing what the plugs look like
[Re: fury4speed]
#2099210
06/27/16 12:43 PM
06/27/16 12:43 PM
RapidRobert
With more thought yes the plugs may have gradually fouled but it sounds like this was a dramatic change. I think you are right on track to checkout the carb, basics, PV/float level/saturation & #1 needle/seat bad. Keep us updated
[Re: fury4speed]
#2099262
06/27/16 02:07 PM
06/27/16 02:07 PM
fury4speed
I will get new Autolite 85's , since I am removing them I might as well install new ones , are they still the spark plug of choice?
[Re: fury4speed]
#2099279
06/27/16 02:24 PM
06/27/16 02:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Seeing you might suspect the power valve, a simple test, the air/fuel idle mixture screws on the primary metering block (1 on each side)located/sandwiched between the front fuel bowl and the carbs main body, start by turning one screw/needle seat all the way in gently seating it, (count the number of turns so you can return it back to it position)if there's no stalling or change in idle, then do the last remaining screw, if it idles with both screws seated, the power valve is toast
Be aware some Holley's have a reverse Idle screw system, turning the screws outward actual closes the seat/passage, but generally such Holleys have a tag/decal on the metering block on each idle screw noting "reverse idle system"
Simple test, cost you nothing, and eliminates the possibility of having a blown power valve
[Re: fury4speed]
#2099336
06/27/16 03:29 PM
06/27/16 03:29 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I will get new Autolite 85's , since I am removing them I might as well install new ones , are they still the spark plug of choice? No, they are offshore source junk now, buy NGK ... yes offshore to, but not low bidder junk.
[Re: fury4speed]
#2099409
06/27/16 05:02 PM
06/27/16 05:02 PM
RapidRobert
if the plugs ain't fouled you might check out the ign systems
