Re: ECU problems?
[Re: 73ChargerSE]
#209910
01/31/09 10:27 PM
01/31/09 10:27 PM
Posts: 1,822 Colorado
denfireguy
Colorado
-HOWEVER, I am only getting from 4-5 volts at the coil. I tried 3 different coils, same story.
What could be causing it not to start? Would it be my ECU? Voltage Regulator? Distributor?
Thanks for any help Paul
With the key in run position, that is the right voltage with the engine not running. In start position with the engine turning over, it should jump to 12V. The voltage should return to 6V with the engine now running. Take a plug wire off and see if you have any spark while the engine is turning over. If you do not, suspect the ECU or the distributor. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: ECU problems?
[Re: 73ChargerSE]
#209914
01/31/09 10:46 PM
01/31/09 10:46 PM
RapidRobert
(1) take the primary wire off of the coil (-) terminal & w key on tap it to a metal ground & see if the coil secondary wire(held 1/4" from ground) sparks (2) Jump 12V from battery positive post to the upstream side of the ballast & crank it w the key & see if it starts.
Re: ECU problems?
[Re: 73ChargerSE]
#209915
01/31/09 10:57 PM
01/31/09 10:57 PM
denfireguy
Colorado
Ballast resistor was a NOS unit, I tried another ballast resistor (not sure if it was good or not) and that didn't work either. I am not getting any spark at the distributor cap. I thought I should be having about 9 or 10 volts at the coil at the run position.
No spark, ECU or distributor. Probably ECU. Ballast is out of circuit on switch in start position. Low voltage on coil is a red herring. Craig
Re: ECU problems?
[Re: denfireguy]
#209916
01/31/09 11:34 PM
01/31/09 11:34 PM
Posts: 353 Tucson, AZ
73ChargerSE
Tucson, AZ
Well I swapped out the ECU for one that was in a running Duster that I've got. No go on that one either. The thing that freaked me out is I realized that when I turn the key off from the start position, the motor reverses it's rotation a small amount and pushes air out of the carburetor. What the heck is going on with my car
Re: ECU problems?
[Re: RapidRobert]
#209918
02/01/09 10:57 AM
02/01/09 10:57 AM
I've seen that a few times, I just assumed it was from the eng being tired.
No what usually causes that, either key on or off, is that a residual spark occurs, is fed through to a plug, and fires a small amount of "compression" in a cylinder
Re: ECU problems?
#209919
02/01/09 11:02 AM
02/01/09 11:02 AM
RapidRobert
got it, that makes sense.
Re: ECU problems?
[Re: RapidRobert]
#209920
02/01/09 11:26 AM
02/01/09 11:26 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Hi, Running from the start, may be you overlooked something obvious ( it is often the case, by experience !)
IF it fires back in in the carb, it means you have spark.......non ?
Voltage is normal, Ecu is ok... wires are fine
Is the cap worn or damaged ? if not... The advance plate moving freely? (not stuck)
Lessen the advance just a notch on the dist to start..(not supposed to turn backwords when turning off)
Did you check the level in the carb ? Clogged primary jets ? Have you tried putting gas in the carb and start it? if it does you'll know where to look..
Dan
Re: ECU problems?
[Re: ThermoQuad]
#209922
02/01/09 02:41 PM
02/01/09 02:41 PM
73ChargerSE
Tucson, AZ
The motor is brand new with new summit double roller timing set. It has less than probably about 50 miles on it. I haven't even had the car on the street enough to get it registered. I'm hoping it's not my timing chain.
Re: ECU problems?
[Re: 73ChargerSE]
#209924
02/02/09 02:54 PM
02/02/09 02:54 PM
denfireguy
Colorado
You did not say if you have a spark yet with the substitute ECU. I forgot to include coil as another possible culprit. To trouble shoot the coil, disconnect the wires going to the negative terminal of the coil. Hook a piece of wire long enough to get to a good ground. Pull the high tension wire that comes from the coil out of the distributor. Place the wire within a half inch of a ground. Take the wire from the negative terminal and tap it to ground. It should develop enough voltage to produce a spark on the coil secondary. Or take the coil out of the donor car you got the ECU from and swap it out. If the coil is working, and the ECU is known to be good, then the problem is in the pickup in the distributor. Craig
Re: ECU problems?
[Re: 73ChargerSE]
#209926
02/02/09 06:48 PM
02/02/09 06:48 PM
RapidRobert
you might sub both of the bad items back in there(1 at a time) that way if only 1 was bad(which'd be my guess) you wouldn't be tossing a good part that could go in your glove box as a spare. but maybe after this you dont want to lay eyes on an ecu or a ballast for quite awhile.
Re: ECU problems?
[Re: 73ChargerSE]
#209927
02/02/09 09:31 PM
02/02/09 09:31 PM
denfireguy
Colorado
I don't know, I think I would leave them both in there and walk very quicly away.....
Re: ECU problems?
[Re: 73ChargerSE]
#209928
02/02/09 10:02 PM
02/02/09 10:02 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
Well I put the substitute ECU and put a new ballast resistor on it and it fired right up. So I think both of those were bad.
My money is on the ballast being bad. You said the ECU worked in your Duster right?
