NHRA Rule on Brake line #209822
01/31/09 08:56 PM
01/31/09 08:56 PM
Gearbox Offline OP
Gearbox  Offline OP
Installing brakelines on my car, thought I read somewhere that the brakeline could not passover the crankshaft centerline? Does this mean my original front brakeline cannot be routed as OEM across the firewall and over to the right front wheel. I'm running a scattershield, I hope I do not have to go all the way up to the rad support and over do I? Car is a 66-B-body with Lamb brakes. Thanks.
Re: NHRA Rule on Brake line [Re: Gearbox] #209823
01/31/09 09:00 PM
01/31/09 09:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thats what I heard about the new rule too. The front brakeline has to cross in front. mike
Re: NHRA Rule on Brake line [Re: Sport440] #209824
01/31/09 09:09 PM
01/31/09 09:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run mine inside a piece of stainless tubing that I attached to the firewall, in an area that passes over the bellhousing,,doing that will make it legal.
Re: NHRA Rule on Brake line [Re: dartman366] #209825
01/31/09 09:38 PM
01/31/09 09:38 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I ran mine up the front frame to the K frame and then thru the K frame to the other side and down the frame rail. Very simple and not much will get at it inside the K frame.
Re: NHRA Rule on Brake line [Re: 70HemiGTX] #209826
01/31/09 09:45 PM
01/31/09 09:45 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I ran my to the radiator suport..that way I could take the K-member out if I wanted to..without messing with the brake line.
Re: NHRA Rule on Brake line [Re: Gearbox] #209827
01/31/09 09:52 PM
01/31/09 09:52 PM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
whats the point of protecting the brake line on just the firewall becase it runs over the centerline of the crank flywheel or converter you could still knock the master cylinder off the fire wall if somthing really comes unglued parts dont just go strait up and down is a 365 degree thing if it comes un-glued if the brake line runs on top or inside edge of the frame rail rods could take it out I would think more protection would be required to accomplish much
Re: NHRA Rule on Brake line [Re: dartman366] #209828
01/31/09 09:53 PM
01/31/09 09:53 PM
South Dakota
dakotahotrodder Offline
South Dakota
Dartman, you got any pictures of that?
Re: NHRA Rule on Brake line [Re: W2DODGE] #209829
01/31/09 10:43 PM
01/31/09 10:43 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
same reason fuel regulator cant be mounted to the firewall, and any fuel lines near the trans have to be shielded. just extra little safety precautions.
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Re: NHRA Rule on Brake line [Re: cmcgee123] #209830
01/31/09 11:45 PM
01/31/09 11:45 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Personal opinion no lines should be on the firewall and everything should be outside the framerails .
