Aluminum master cylinder question #2097411
06/24/16 03:21 PM
06/24/16 03:21 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
I'm replacing my master cylinder ('70 Cuda) with a later model aluminum version. Can I use a parts store replacement ('88 Diplomat would work)?
Or do I need to spend the extra $ for Doctor Diff's version?
What are you guys using?
Re: Aluminum master cylinder question [Re: WarEagle1] #2097430
06/24/16 03:37 PM
06/24/16 03:37 PM
you would just need the right bore dia & if manual brakes, that the rear piston cavity (the thimble) has a circular recess about halfway down into it for the pushrod neoprene nub to lock into (PB can work with or without the recess)
Re: Aluminum master cylinder question [Re: RapidRobert] #2097443
06/24/16 03:49 PM
06/24/16 03:49 PM
Alabama
W
W
Alabama
Mine does have manual brakes. Seems like the brake light switch would not allow the pedal to come back far enough for the pushrod to ever disengage. Thoughts?
Re: Aluminum master cylinder question [Re: WarEagle1] #2097446
06/24/16 03:51 PM
06/24/16 03:51 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Check with Dr. Diff (Cass) . . . he knows all !
Re: Aluminum master cylinder question [Re: a12rag] #2097454
06/24/16 04:05 PM
06/24/16 04:05 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
iagree
Get Cass's input and then you can make an informed decision.
...FAFO...
Re: Aluminum master cylinder question [Re: WarEagle1] #2097472
06/24/16 04:29 PM
06/24/16 04:29 PM
BDW Online content
BDW  Online Content
Parts store is fine, plus you get lifetime warranty.
Brake light switch is on a bracket that's adjustable.
Re: Aluminum master cylinder question [Re: WarEagle1] #2097536
06/24/16 07:09 PM
06/24/16 07:09 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I assume that if you buy the smaller bore master from Cass, he has already modified the piston for the push rod/retainer?
Re: Aluminum master cylinder question [Re: BDW] #2097573
06/24/16 08:52 PM
06/24/16 08:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That reply gets saved in my "Moparts Tech worthy" threads up
Re: Aluminum master cylinder question [Re: jcc] #2097614
06/24/16 10:17 PM
06/24/16 10:17 PM
the alum MC's will have a different base flange thickness and the piston will likely be at a different depth than the OE iron MC plus you'll likely use the 4 bolt to 2 bolt adapter plate all of which will affect pushrod length needed so figure you might be needing the MP adjustable pushrod after mockup
Re: Aluminum master cylinder question [Re: RapidRobert] #2097713
06/25/16 01:50 AM
06/25/16 01:50 AM
fullmetaljacket Offline
Dr Diff will set up the right stuff for you.
Re: Aluminum master cylinder question [Re: fullmetaljacket] #2097784
06/25/16 10:47 AM
06/25/16 10:47 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I went with the 85 Dodge Diplomat MC because I actually have 10 pistons in my brake system,Wilwoods on the rear and factory discs on the front.
The tech section on the Mark Williams site suggested a 1" bore with the brake system I'm using. I'm probably going to finish my brake upgrade this weekend so I'll post back and let you know how it fits.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Aluminum master cylinder question [Re: fourgearsavoy] #2098488
06/26/16 01:43 PM
06/26/16 01:43 PM
Eberg once made mention of filling the cavity with RTV to lock the pushrod into a piston without the manual brake recess. At first blush it sounded hokey but with more thought I think it'd be secure & Eberg has forgotten more tech than I will ever know
Re: Aluminum master cylinder question [Re: jcc] #2098516
06/26/16 02:34 PM
06/26/16 02:34 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Times 2 up
I have mechanical Aptitude.
I can screw up anything.
