Leaf spring car rake? #2097701
06/25/16 01:26 AM
06/25/16 01:26 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Is there a need or benefit for a mono leaf cal trac car to have any rake? I just changed the back halfs on my monos and my car is sitting pretty much level now. It has about 1/4" rake with the back being higher than the front.
Re: Leaf spring car rake? [Re: justinp61] #2097705
06/25/16 01:34 AM
06/25/16 01:34 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Should make for better weight transfer.
[image][/image]
Re: Leaf spring car rake? [Re: justinp61] #2097706
06/25/16 01:35 AM
06/25/16 01:35 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
No I don't see any. My car was almost level also.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Leaf spring car rake? [Re: 1967dartgt] #2097719
06/25/16 02:21 AM
06/25/16 02:21 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Leaf spring car rake? [Re: justinp61] #2098005
06/25/16 05:20 PM
06/25/16 05:20 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Mines at 1.25" and 60fts a 1.38s...
Re: Leaf spring car rake? [Re: justinp61] #2098058
06/25/16 07:00 PM
06/25/16 07:00 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Mine sits level and low
Re: Leaf spring car rake? [Re: justinp61] #2098143
06/25/16 09:56 PM
06/25/16 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have big torque the assend up a bit helps
but if your lower torque you would like that and the
engine sitting higher... makes for easier transfer..
and depends on the weight ratio front to rear
wave
Re: Leaf spring car rake? [Re: MR_P_BODY] #2098184
06/25/16 11:18 PM
06/25/16 11:18 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
wave [/quote]
Mr.Pbody can you please elaborate on the first part of your post
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Leaf spring car rake? [Re: turbo toad] #2098186
06/25/16 11:23 PM
06/25/16 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Thanks [/quote]
If the back is higher it takes more torque to get
the front above the CG
wave
Re: Leaf spring car rake? [Re: justinp61] #2098260
06/26/16 01:38 AM
06/26/16 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As said the lower rear can help the car hook better. Gets the weight over the rear tires more. Myself I have my car the way I like it. I like the Nostalgia look with just a tiny rake with the rear a tad higher. But thats just my taste as thats what I like as I dont care for the slammed down look on the 60's muscle cars since its not the Nostalgia look I like alot. But its your car so you have to have it how you like it. It sounds like it sits real nice right now. Sitting level or a tad higher in the back is how most bracket cars seem to sit. I would leave it as is if your happy with it and try it at the track. Ron
Re: Leaf spring car rake? [Re: justinp61] #2098264
06/26/16 01:47 AM
06/26/16 01:47 AM
W. Kentucky
W. Kentucky
Thanks guys, I'm going to have to go back to what I had. The tires won't come off and the shocks don't have much room to compress. I went 1.38 with the old springs so I'm sure with the new shocks they will work fine.
