E.T. Gains from open headers
#2097685
06/25/16 12:52 AM
06/25/16 12:52 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
What kind of gains in E.T. and speed would unhooking the exhaust pipes from the headers could I see at the track? I run TTI headers with a 3" collector into 2 1/4 pipes through Ultra Flows and out to the chrome tips. Also would header extensions be beneficial? It runs great with the setup, just wondering if it was worth the effort to unhook them. Motor is a 416 stroker. Thanks!! Greg
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
Re: E.T. Gains from open headers
[Re: G-Money1320]
#2097690
06/25/16 12:56 AM
06/25/16 12:56 AM
Posts: 4,457 Washington
madscientist
Washington
You will most likely go slower with open headers if you do not add collector length. I start at 12 inches and go longer til it slows down.
All you preverts can just let that go.
I learned this years ago when guys picked up with mufflers. They were adding collectors length. Most collectors are too short IMO.
[Re: G-Money1320]
#2097693
06/25/16 01:06 AM
06/25/16 01:06 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I think you will pick up a lot !!! I would bet 4 tenths with that 21/4 pipe gone.maybe more.
[Re: G-Money1320]
#2097704
06/25/16 01:30 AM
06/25/16 01:30 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
2-3 tenths very likely. Maybe more. Adding a tailpipe to the collector would help also, but it sounds like you are just unbolting the exhaust, not removing it. Probably not enough room underneath to add tailpipes.
[image][/image]
[Re: sgcuda]
#2097755
06/25/16 08:15 AM
06/25/16 08:15 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
2-3 tenths very likely. Maybe more. Agreed. My Duster picked up 2-3 tenths (13.0 car) and my GTX (11 sec car) would pick up 4 with crappy flowmaster muffler system.
"I think its got a hemi"
[Re: G-Money1320]
#2097801
06/25/16 11:32 AM
06/25/16 11:32 AM
Posts: 3,210 robin hood country
deaks
robin hood country
A friend of mine had a 383 satellite that ran 12.8 with 2-1/4 pipes, dropped .4 just unbolting the pipes, didn't even take them off. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: G-Money1320]
#2097907
06/25/16 02:34 PM
06/25/16 02:34 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
It will probally pick up enough to make you wonder why it did that much I had a 440 motor in a 1969 Dart with Hooker fenderwell headers with 3.5 inch collectors running into 2.5 inch head pipes about 20 inche long running into a old set of 2.5 Turbo muffllers and then out with 2.5 inch side tail pipes that ended in front of the rear tires. That car ran a best 12.23 at 109.5 MPH with the exhaust system on at LACR 1/4 mie track, it ran 11.39 at 117.& MPH with it removed My next pump gas street car ran a best of 7.01 at 95.3 MPH in the 1/8 mile with a 3 inch system with 3x14 inch oval Magnaflows straight through mufflers, I removed that system, it went all the way to the back bumper, and the car picked up to 6.98 at 95.5 MPH Bottom line is all of our cars don't react and get the exact same results with the same changes Let us know your results please, more data to the data base
[Re: G-Money1320]
#2097910
06/25/16 02:37 PM
06/25/16 02:37 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
My guess is it will pick up WAY less than most here are saying. Less than a tenth.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: G-Money1320]
#2097916
06/25/16 02:51 PM
06/25/16 02:51 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
On my old 3" w/ flowmaster 40's WAY less then a .10 second gain. Wasn't worth the hassle to unbolt them. Plus how it is on the street, is how I race it at the track Bet you'd see bigger gains on a supercharged/turbocharged setups.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: G-Money1320]
#2098197
06/25/16 11:36 PM
06/25/16 11:36 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
3" into 2.25" is the problem area, I think 2 tenths.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: G-Money1320]
#2098206
06/26/16 12:00 AM
06/26/16 12:00 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Next weekend is the Mopar race at Milan so I think I will unbolt it and see what it does and report back here. I am with you Darth that how it is on the street is how its raced but with more power the curiosity is killen me Add a collector extension.. for a total length of 16".. dump the exhaust and those muffs.. they have high back pressure... you should pick up a couple of tenths anyways.. maybe more but you will need to re tune the carb
[Re: MR_P_BODY]
#2099164
06/27/16 11:34 AM
06/27/16 11:34 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Depends mainly on how restrictive the system is and how optimized the A/R ratio is at WOT pulling through the load.
Over 30+ years I've seen >1/2 second on a super-restrictive system, and then I've seen only a couple hundreths, and depending on suspension and traction it may possibly/mainly show up only as MPH.
Going from a small but free flowing dual 2 1/4 to open headers I'd expect .08 to .2, tough to tell but you'll improve. May want to bring some jets +2 to +6 from where your at now.
[Re: G-Money1320]
#2099236
06/27/16 01:29 PM
06/27/16 01:29 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
My 360 makes 450-500hp on a good day. I have a 3" system to ultra flow mufflers and it goes out 2.5" tailpipes. It's all muffler shop bent stuff. I put some exhaust cutouts about 12" back and with them open it is .1 and 1mph faster.
When I went from flow masters to ultra flows it picked up 2mph roughly, I changed some other stuff also so it's hard to tell but they for sure helped. I also quit getting a sooty intake after I lost the flow masters
68 Barracuda Formula S 340
[Re: G-Money1320]
#2099333
06/27/16 03:27 PM
06/27/16 03:27 PM
Posts: 2,158 Hamilton,Ohio
POZEST
Hamilton,Ohio
I say you will pick 3 tenths. Get that rollbar in big money!
"I'm not a Gynecologist, but I'll take a look."
[Re: G-Money1320]
#2099362
06/27/16 03:55 PM
06/27/16 03:55 PM
B3422W5
Portage,michigan
I kinda have to outright laugh at some of these replies. 3 or 4 tenths is like 50 or 60 horsepower on this engine( or more). Just don't see it at all. That's like going from stock J heads to Eddie heads. I picked up 4 tenths doing that years ago on a 340 with boltons. Gaining the same by ditching exhaust.... Lol
[Re: G-Money1320]
#2099376
06/27/16 04:08 PM
06/27/16 04:08 PM
Bad340fish
Tulsa OK
2.25" AND flowmasters tells me he will see more than my .1 but .5 eh I dunno.
[Re: G-Money1320]
#2099384
06/27/16 04:18 PM
06/27/16 04:18 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
On my chasis dyno we see from 3hp to max 15-18 hp gain with cutouts open. depending on the placement of them sometimes it was a pay cut!!!
JAKES AUTOMOTIVE
