Re: Special shout out to Monte Smith
[Re: old yeller]
#2097568
06/24/16 08:36 PM
06/24/16 08:36 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I saw him on the show Monday night.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: SpareParts]
#2098080
06/25/16 07:36 PM
06/25/16 07:36 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Hahaaha.
Way to go Bird.... I want to call Monte but my wallet doesn't want to yet Awwww, go ahead. I am not the cheapest, but I am by far not the most expensive either...........LOL!!!
[Re: Monte_Smith]
#2098134
06/25/16 09:35 PM
06/25/16 09:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Monte.. since I've never played with spray... do the injectors screw in or are they like regular injectors with the O-rings that have to be mounted... I looked at my brothers system one time but forgot got if its a screw in EDIT I assume you use 3/16 tubing for all the lines
[Re: old yeller]
#2098177
06/25/16 11:09 PM
06/25/16 11:09 PM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
My fogger nozzles screw in. IIRC, they are 1/8" pipe thread, but I haven't looked at them for awhile.
[Re: slantzilla]
#2098183
06/25/16 11:17 PM
06/25/16 11:17 PM
MR_P_BODY
My fogger nozzles screw in. IIRC, they are 1/8" pipe thread, but I haven't looked at them for awhile. Thats what I thought thanks
[Re: Monte_Smith]
#2098345
06/26/16 04:55 AM
06/26/16 04:55 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Hahaaha.
Way to go Bird.... I want to call Monte but my wallet doesn't want to yet Awwww, go ahead. I am not the cheapest, but I am by far not the most expensive either...........LOL!!! I said "YET" lol, I know my flow sheet would be way more complete than the company that did it but that's another story
[Re: MR_P_BODY]
#2098357
06/26/16 06:29 AM
06/26/16 06:29 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
My fogger nozzles screw in. IIRC, they are 1/8" pipe thread, but I haven't looked at them for awhile. Thats what I thought thanks About 20 years ago I equipped my turbo BMW with a single Fogger nozzle to spool the turbo up quicker. It was a so-called 1/16" NPT thread and I had to buy a special tap for it. I think it's not a real pipe size (1/8 is the smallest I have seen) but I'm sure NOS sells the proper tap. There may be 1/8" threads on these too, better look closely.
[Re: old yeller]
#2098651
06/26/16 06:00 PM
06/26/16 06:00 PM
Monte_Smith
North Alabama
90% of fogger nozzles are 1/16 NPT and it is nothing special..........just a common pipe thread.
3/16 is the common hardline size, but depending on application, I have also used 1/8 hardline as well as 1/8 "softlines" which is basically high pressure nylon tubing. We source out some special "pushloc" fittings to use the softlines. Usually a quick and easy way to add a second, third or fourth kit to a tight manifold.
EFI and DRY nitrous makes things easy. With the right nozzle, or a properly modified nozzle, in a DRY application you also put nitrous through the fuel side of a nozzle. Essentially making a regular fogger a two stage dry kit. I and others, also now make a 3 stage dry nozzle. I put this nozzle on both the inside and outside of our manifold for new engine. So we now have a 6 stage dry kit manifold. Six stages is NOT about MORE nitrous, because I can put all the motor can stand through two. It's about power management with 6 small kits, versus fewer BIG kits
[Re: SpareParts]
#2098667
06/26/16 06:16 PM
06/26/16 06:16 PM
Monte_Smith
North Alabama
Hahaaha.
Way to go Bird.... I want to call Monte but my wallet doesn't want to yet Awwww, go ahead. I am not the cheapest, but I am by far not the most expensive either...........LOL!!! I said "YET" lol, I know my flow sheet would be way more complete than the company that did it but that's another story Yeah, a lot of times the "sheet" consists of use this jet and this jet, at this fuel pressure, with no real numbers, what those numbers mean and how to use them. While I don't mind taking a call every time a guy wants to make a change, I actually prefer to teach them what the numbers mean and how to use them and then make their own changes. The customer learns more that way, than just doing what I tell them to. Too many guys are secret squirrel about this stuff. It's NOT rocket science, just have to understand it and what you are trying to do
