I just bought 2 new cams for my 416.. but on the
one I would have to buy new intake rockers.. dont
feel like doing that... they cost more than the cam
but the second one looks better for the long run.. I
can keep the same rockers and be very close to the same
lift with a little less duration... both were ground on
a 110 lsa so the EFI will like it better... I always use
the lifter for checking center line... but then I check
the retainer to see what the final lift is(being a SB you
lose a fair amount)... once I get the other cam I will swap
out my heads and the cam... I have the W-2s on it now but I
will put my W-5s back on... dont know if I will set the center
line at 104 or 106
