Another Mid Plate Question
#2097092
06/24/16 12:45 AM
06/24/16 12:45 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Instead of running a mid plate between the block and bell housing, I am thinking of putting a plate between the bell housing and the transmission (5 speed manual). The Quicktime housing has extra bolt holes that I can use to fasten the plate to independent of the trans bolt. The reason would be for easier removal of the engine without removing the tranny, or the tranny without removing the engine. Any reason why this won't work? Does this go against NHRA or IHRA rules?
[image][/image]
Re: Another Mid Plate Question
[Re: sgcuda]
#2097099
06/24/16 12:52 AM
06/24/16 12:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The reason for the mid plate is to hold up the back of the engine if you blow the trans.. back there it wouldnt help.. put the mid plate where it needs to be.. if your concerned about engagement .. put washers between the flex and conv pads EDIT maybe just send the conv back, all the others say you have to
[Re: sgcuda]
#2097205
06/24/16 08:53 AM
06/24/16 08:53 AM
sgcuda
Mr P. It's a stick, so I'm out on this "Converter spacing debate". If the tranny breaks in two, the engine would still be supported at the back of the bell housing. Likewise, if the engine needs to be removed, the tranny and bell housing can remain in place.
[image][/image]
[Re: sgcuda]
#2097211
06/24/16 09:22 AM
06/24/16 09:22 AM
MR_P_BODY
The only problem with pulling the engine with a mid plate is you need a removable trans tunnel to get the trans bolts(to make life easy)... to be honest when you said you wanted to put it in the rear I dont think that would pass(if they look)
[Re: sgcuda]
#2097603
06/24/16 10:00 PM
06/24/16 10:00 PM
sgcuda
AND if you need to service the clutch, you will have to remove your mount and support engine.
Oh, yeah. I completely forgot about that clutch thing. I hate getting old.
[image][/image]
