car sits sideways????
#209703
01/31/09 06:59 PM
01/31/09 06:59 PM
Posts: 219 so cal
cmcgee123
so cal
looking at my car after i took it out to irwindale on thursday and it looked like it was sitting sideways. so i checked tire pressure set fronts to 40 psi and rears to 13 even accross the car. the front right is 1 1/8" lower than front left and the rear right is 2" lower than rear left. the car has a lader bar and coilover rear suspension and stock torsions up front. it launches straight but i was just wondering if the preload on my right rear tire could be causing this???? the car hasnt been on the scales yet would it be worth the time and money to get this done? and would the car be able to sit level all around if i have the car scalled?
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Re: car sits sideways????
[Re: cmcgee123]
#209705
01/31/09 07:05 PM
01/31/09 07:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You would be better off having it scaled, it can be level but not always(to get a good balance), once its scaled set in the pre-load(with you in the seat)
[Re: Quicktree]
#209707
01/31/09 07:25 PM
01/31/09 07:25 PM
MR_P_BODY
I wouldn't mess with the preload if the car leaves straight.
If he changes the height.... it will change the pre-load
[Re: Irun5snd8th]
#209713
01/31/09 11:20 PM
01/31/09 11:20 PM
Posts: 219 so cal
cmcgee123
so cal
guess i will just have to take it to the scales and see what happens... but it leaves straight so i really shouldn't care. but [Edited by Moparts - Keep it clean] soon as i noticed it every time i look at the car it seems to be leaning more and more its like the little dent as soon as you see it. it becomes a big deal.
[Re: cmcgee123]
#209714
02/01/09 01:00 AM
02/01/09 01:00 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
If you think its preload pull one of the ladder bar front bolts out and then set it on the ground and see if sits level. If its preload the car will now sit correct. if its still uneven its probably one of the front torsion bars.
No matter what you should get the car to sit correctly with the one ladder bar disconected then put the bars on and scale it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: cmcgee123]
#209717
02/01/09 02:58 PM
02/01/09 02:58 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
What rear axle do you have, - 8 3/4? I've Seen twisted housings cause similar condition
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
