I found my broadcast sheet and am wanting to know some more options that it may have had.
What are the rear axle codes? I have 5 in the space and cant make out if there is any other # beside of it. ga4=gunmetal grey
T-u-W=64
fan=24
fan spa=55
bat=51
v stripe =First box=8x/second box=9x
vac fit=26?
engine=348
trans=821
pin=34
p/shaft=652
axle=006
wheels (88=road,color=tx8,spare=12)
wheel cover=9
frame=60
shock -front/52, rear=93
rear spring =072 (l and r)
clutch brake pedal =12/10
master cylinder=11
front brake=lt/50,rt=50
heater a/c (blank, even though car has heater??)
section 11..radio=11, wheels=2
Everything else kinda hard to make out. Thanks!
