Re: Easy torsion bar removal
[Re: CKessel]
#2088703
06/08/16 11:28 PM
06/08/16 11:28 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Getting ready to do this tomorrow...Thanks!
[Re: CKessel]
#2088939
06/09/16 11:32 AM
06/09/16 11:32 AM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
Will be doing it on my 65 Coronet that hasn't had the bars out since the early 80's.
Carl Kessel
[Re: CKessel]
#2096844
06/23/16 04:40 PM
06/23/16 04:40 PM
Posts: 133 Parsippany, New Jersey
340challconvert
I am in the process of rebuilding the front end and suspension of my 70 A66 Challenger vert Did some research on this before I started
Cleaned the torsion bar rear cross member slot out, soaked with CRC after removing the clip Sprayed the CRC in the front K frame area where the bar goes in Removed bolts holding the strut in (after soaking of course) Removed the sway bar bolts to the K frame Removed the bolt going to the lower control arm stud Lightly pried the lower control arm back
I was lucky- torsion bar slid right out in back.
Was surprised, but I soaked everything CRC, cleaned out areas where I could reach. Everything worked out without the need for the torsion bar removal tool.
Rebuilding the lower control arm and bushing removal will be a story for another day!
1970 A-66 340 Challenger convertible
[Re: CKessel]
#2096862
06/23/16 05:06 PM
06/23/16 05:06 PM
Posts: 22,697 Bitopia
jcc
Bitopia
For those watching the OP's link, do not adjust your monitor I swapped out two TB sets this morning. On my cars I can seldom get away without at least removing the UCA droop snubber and or the shock lower thru bolt. On a related note, anybody use a "system" to mark their TB's? I paint the rear ends of the TB's, red for left, white for right, also helps slightly read the numbers if needed when installed. I'm also ditching the TB rear boots, they don't like the bigger bars, seem to tear on frequent changes, my cars don't see a lot of inclement weather, and never dirt roads. Dab of grease for me. edit: The above is incomplete. the OP's link noting loosening the LCA nut and knocking pin loose is the method on OEM rubber type bushings, on my recent experience with nylon/delrin and greaseable LCA pins, not so much. Sorry for any misdirection.
[Re: Supercuda]
#2097015
06/23/16 11:01 PM
06/23/16 11:01 PM
340challconvert
Sorry, probably showing my age. CRC was at the time, the generic term we used for the penetrant/lubricant, basically rust buster that we used in the shop I worked in 40 years ago. Worked great then, works great now. Guess they expanded their line of products in the last 4 decades
Kind of like "Liquid Wrench", we also used their penetrant, but they make other products. Just another shop term from back in day!
[Re: CKessel]
#2097075
06/24/16 12:20 AM
06/24/16 12:20 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
When I think CRC I think Brakleen, I was thinking you were cleaning the old grease out.
[Re: CKessel]
#2097154
06/24/16 02:07 AM
06/24/16 02:07 AM
Supercuda
About to go away
About to go away
up yours
Just don't get any in your eye, it hurts, alot.
[Re: CKessel]
#2097833
06/25/16 12:25 PM
06/25/16 12:25 PM
CKessel
Los Osos, Ca
For sure you need to remove any goo and junk from the socket area before. The Challenger that I was working on was fairly clean but there were some burrs in the socket that prevented them from sliding out. A couple of licks with a file and zippity doo dah they came out. For sure the rust belt boys will have more of a challenge. Like I said in the video, which I'll try to redo with a better camera so's its more clear, it may not work for everyone depending on the condition of your car. I'm glad its working out for some of you though!
Carl Kessel
[Re: CKessel]
#2100869
06/30/16 12:27 AM
06/30/16 12:27 AM
Supercuda
About to go away
About to go away
up yours
Lots of mechanics think they are mechanics because they can spell mechanic.
It's called a stress riser. Will it cause a failure, depends, can it cause a failure, yes.
In low performance stock type usage, the likelihood of a failure is at it's lowest, short of not using it at all. In this forum I'd say the likelihood is higher, especially with higher rate bars.
Lots of technical papers out there covering this.
[Re: CKessel]
#2100889
06/30/16 12:42 AM
06/30/16 12:42 AM
Supercuda
About to go away
About to go away
up yours
Ask him if he'd put a rod in that had a nick on the beam. If he says yes he's not a good mechanic, if he says no ask him why.
Same reason for not nicking a torsion bar.
