deck height variances ?
#2096868
06/23/16 05:13 PM
06/23/16 05:13 PM
Posts: 3,210 robin hood country
deaks
robin hood country
My ross pistons for my stroker are .017 in the hole, so i'm going to have the deck milled and the machinist is talking about mocking the pistons up to check how square they are, which is a bit of a pain as it means extra journeys and it got me thinking what amount it could be out. Years ago, i checked one of my old engines with TRW six pack pistons and it was about .003 from lowest to highest. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: deck height variances ?
[Re: deaks]
#2096900
06/23/16 06:32 PM
06/23/16 06:32 PM
deaks
robin hood country
At .003 you could deck it .014, get good quench and no piston would be above deck. Mick
[Re: dogdays]
#2097535
06/24/16 07:08 PM
06/24/16 07:08 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Decks can also be tilted, not perpendicular to each other and to the bores.
R. Sounds like the GM "W" 348 and 409 engines with a 74-degree deck angle.
[Re: 451Mopar]
#2097650
06/24/16 11:53 PM
06/24/16 11:53 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
The first time I ran into different length rods was when I was assemblyimg a NHRA legal Stocker 425 HP M.W. motor, I had used the #1 rod and piston to check all four corners and then had the block cut to get the NHRA legal spec. deck hieght. I assembled the motor and decided to check the deck hieght on all eight pistons luckily, I saw from -.017 to -.028, .023 was the spec. deck hieght I was shootong for so I ended up calling the machine shop that I had taken all the 1963 M.W. rods I had (43 of them)and the eight pistons to build that short block to find out what had went wrong. It was the rod center to center lengths. I had assumed he would get the center to center lengths perfect It ended up he had no way of doing that Never assume I've ran into block that tapered from the front to back on one side one way and the exact opposite on the other side I've also seen them tapered from the cam side to the motor mount side, a real beech to get the intake sealed up properly If a man is involved making it, he will screw some of them up
[Re: deaks]
#2097754
06/25/16 08:04 AM
06/25/16 08:04 AM
deaks
robin hood country
After reading this, i will take it back after mock up, thanks for the replies. Mick
[Re: deaks]
#2097796
06/25/16 11:21 AM
06/25/16 11:21 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Wow, there's no way to accurately measure the rods and machine them to be all the same exact length?
**Photobucket sucks**
[Re: 70Cuda383]
#2097913
06/25/16 02:48 PM
06/25/16 02:48 PM
Posts: 31,029 Oregon
AndyF
Wow, there's no way to accurately measure the rods and machine them to be all the same exact length? It can be done but it requires some special fixturing which not all shops have. Shops that do rebuild work don't care about matching rod length since if it came from the factory then it is good enough to go back in a rebuild.
[Re: 70Cuda383]
#2097915
06/25/16 02:49 PM
06/25/16 02:49 PM
Cab_Burge
Wow, there's no way to accurately measure the rods and machine them to be all the same exact length? Most good Hi Po shops can do that now Ask them first though I've seen .003 differences in length on a good brand afterarket steel race rods
