Re: HELP FAST My 440 IS SQUEALING
[Re: blownzoom440]
#209665
01/31/09 09:04 PM
01/31/09 09:04 PM
Check to see if the vibration damper is rubbing the timing chain cover. The rubber cushion which bonds the outer weighted part of the damper to the inner part can deteriorate causing separation of the two pieces. Happened on two of my RB's. Made a heck of a racket and ground a portion of the timing cover away.
#209666
01/31/09 09:47 PM
01/31/09 09:47 PM
RapidRobert
The round metal oil slinger might be making contact on the inside
