How much can the 727 flex band take? #2096614
06/23/16 04:41 AM
06/23/16 04:41 AM
Finland, Europe
Ck[FIN] Offline OP
Ck[FIN]  Offline OP
Finland, Europe
I have used flex band for several years in my 727 with little to zero problems.
I used raptor trans carbon fiber flex band for about 100runs and replaced because it started to bend where the strut goes. Surface material was still in good shape.
I replaced it with raybestos pro series band and it lasted about 10runs. Then it snapped in two pieces. It broke from the first row of rivets.
4.2 lever, 11% bigger sonnax servo, 165psi griner vb.
Maybe try 3.8? Still should work under 900hp?
I ordered new red one from cope and it looks beefier. I know i should have used rigid one but no money at the time (never got too much smile )
How long is your band lasting?
-1965 Valiant 9.03s 358cu.in R5P7-
Re: How much can the 727 flex band take? [Re: Ck[FIN]] #2096623
06/23/16 07:43 AM
06/23/16 07:43 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Broke 1st one after about 5 years daily use plus racing . Got maybe 18 months 2nd one . Both were flex with 5.0 lever . In december i went solid kevlar lined band and 4.2 lever . Smoother crisp shift , hoping it lasts well this time .
Griner rmvb
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: How much can the 727 flex band take? [Re: tex013] #2096682
06/23/16 11:41 AM
06/23/16 11:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Griner rmvb
Tex
That was a bad band choice if you used Kevlar on the front band , they don't hold up well stopping a spinning drum. they are fine for the rear band because they don't apply on a spinning drum but not on the front .
