Re: Best lifter to choose from......
[Re: Moparnut426]
#2093639
06/17/16 06:51 PM
06/17/16 06:51 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Morel IS made in the USA! Get your wallet out if you want good lifters.
unions....the folks who brought you the weekend!
[Re: Moparnut426]
#2094876
06/20/16 11:26 AM
06/20/16 11:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Has anyone tested what the rockwell C is on a lifter.. I expect the riding surface(that rides on the cam) to be about 60-62 rockwell C.. but I have never tested it
[Re: Moparnut426]
#2094921
06/20/16 12:41 PM
06/20/16 12:41 PM
Posts: 7,506 Az
Crizila
Az
Unless you are a metallurgist, the smart choice is to go with the lifter that is recommended by the cam Mfg. - JMO.
Fastest 300
[Re: Moparnut426]
#2094980
06/20/16 02:27 PM
06/20/16 02:27 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
you can get morels threw scotty brown @competition componants616 499 6223
JAKES AUTOMOTIVE
[Re: Moparnut426]
#2095065
06/20/16 04:04 PM
06/20/16 04:04 PM
Posts: 7,506 Az
Crizila
Az
Thanks Jake,
Crizila, Cam manufacturers use a number of lifters from different suppliers, the orders are filled per number that can be filled just like any other big company. They are just sending a spec and receiving a part to that spec. As long as the lifter is for that engine its just as good as any other lifter.
But in my case, I know that the majority of the cam lobe failures are lifters, not camshafts. I just don't want that issue. Yeah Hughes sells their cams with a guarantee of a no lobe failure on break in, but theres stipulations big time!!. So I guess Ill just do some digging.
I should have bought the schubeks a few years ago when I had the chance.
and 95% of lifter failures is DIRT - lifters not rotating in the bores.
Fastest 300
