Best lifter to choose from...... #2093418
06/17/16 10:42 AM
06/17/16 10:42 AM
Finally a HUSKER again
Moparnut426 Offline OP
Is there a USA made good quality lifter to choose from? I have read in the past that they are hard to find and kinda expensive.
Curious what you guys like, and dislike...
Re: Best lifter to choose from...... [Re: Moparnut426] #2093459
06/17/16 12:28 PM
06/17/16 12:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Hydraulic, solid, flat tappet, roller? confused
Re: Best lifter to choose from...... [Re: Moparnut426] #2093566
06/17/16 04:19 PM
06/17/16 04:19 PM
AndyF Offline
AndyF  Offline
How would you ever know unless you visit the factory and do an audit of all of the materials? I worked in manufacturing for a few years and suppliers were constantly changing. Having said that, Morel is probably made in the USA and they have a bunch of lifters. Crane, Crower, Isky, etc. are probably made in the USA but I don't know for sure.
Re: Best lifter to choose from...... [Re: Moparnut426] #2093639
06/17/16 06:51 PM
06/17/16 06:51 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
Morel IS made in the USA!
Get your wallet out if you want good lifters.
unions....the folks who brought you the weekend!
Re: Best lifter to choose from...... [Re: Moparnut426] #2094873
06/20/16 11:14 AM
06/20/16 11:14 AM
Hydraulic flat tappet BTW,
Ive seen a lot of crappy lifters out there, Don't want to deal with issues...
Re: Best lifter to choose from...... [Re: Moparnut426] #2094876
06/20/16 11:26 AM
06/20/16 11:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Has anyone tested what the rockwell C is on a lifter..
I expect the riding surface(that rides on the cam) to
be about 60-62 rockwell C.. but I have never tested it
wave
Re: Best lifter to choose from...... [Re: Moparnut426] #2094921
06/20/16 12:41 PM
06/20/16 12:41 PM
Az
Crizila Offline
Crizila  Offline
Az
Unless you are a metallurgist, the smart choice is to go with the lifter that is recommended by the cam Mfg. - JMO.
Fastest 300
Re: Best lifter to choose from...... [Re: Moparnut426] #2094980
06/20/16 02:27 PM
06/20/16 02:27 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
you can get morels threw scotty brown @competition componants616 499 6223
JAKES AUTOMOTIVE
Re: Best lifter to choose from...... [Re: Moparnut426] #2095007
06/20/16 02:51 PM
06/20/16 02:51 PM
Thanks Jake,
Crizila, Cam manufacturers use a number of lifters from different suppliers, the orders are filled per number that can be filled just like any other big company. They are just sending a spec and receiving a part to that spec. As long as the lifter is for that engine its just as good as any other lifter.
But in my case, I know that the majority of the cam lobe failures are lifters, not camshafts. I just don't want that issue. Yeah Hughes sells their cams with a guarantee of a no lobe failure on break in, but theres stipulations big time!!. So I guess Ill just do some digging.
I should have bought the schubeks a few years ago when I had the chance.
Re: Best lifter to choose from...... [Re: Moparnut426] #2095065
06/20/16 04:04 PM
06/20/16 04:04 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By Moparnut426
Thanks Jake,
and 95% of lifter failures is DIRT - lifters not rotating in the bores.
Fastest 300
Re: Best lifter to choose from...... [Re: Moparnut426] #2095141
06/20/16 06:17 PM
06/20/16 06:17 PM
Yeah, Dirt, metal, general not slippery stuff creates havoc on any metal to metal surfaces...
Re: Best lifter to choose from...... [Re: Moparnut426] #2096327
06/22/16 05:19 PM
06/22/16 05:19 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Buy a name brand with the EDM hole and you should be good. I get my cams and lifters from Jones Cams... He has his lifters made to his specs.
