Valve Covers for Trick Flow 240 Heads #2096162
06/22/16 11:42 AM
06/22/16 11:42 AM
Spanaway, Washington State
P
patosmith Offline OP
P
I have been having troubles with oil leaks and I am finding that the TF 240 heads are narrower than stock making stock and aftermarket valve covers hard to seal.
Anybody using these heads and what are you doing for valve covers.
I am at a loss. I've tried 3 times to get the covers to stop leaking.
Any ideas?
Thanks.
Re: Valve Covers for Trick Flow 240 Heads [Re: patosmith] #2096360
06/22/16 06:27 PM
06/22/16 06:27 PM
AndyF Offline
AndyF  Offline
I solved that problem by making my own valve covers. A cheaper option is to find a set of valve covers that actually fit. By fit, I mean the rails on the valve cover match the rails on the head. Most cast covers are made too wide so they don't line up with the rails on the head. When you tighten them down they twist the gasket and cause the leak.
Re: Valve Covers for Trick Flow 240 Heads [Re: patosmith] #2096414
06/22/16 09:18 PM
06/22/16 09:18 PM
WA
tman Offline
tman  Offline
WA
Contact TF. They may give you a lead.
Re: Valve Covers for Trick Flow 240 Heads [Re: patosmith] #2096552
06/23/16 12:50 AM
06/23/16 12:50 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Any particular reason why when you're spending big bucks on aftermarket heads they can't get the rails right?
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Valve Covers for Trick Flow 240 Heads [Re: patosmith] #2096686
06/23/16 11:44 AM
06/23/16 11:44 AM
P
P
I contacted TF and the guy said this is the first they heard of this problem.
AndyF, I sent you a PM.
Thanks everyone.
