Leaf spring bushings
#2095378
06/21/16 12:40 AM
06/21/16 12:40 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
Most are aluminum with a steel sleeve. Is there any reason they can't be made in solid steel?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Leaf spring bushings
[Re: poboyengineering]
#2095781
06/21/16 06:16 PM
06/21/16 06:16 PM
poboyengineering
pennsylvania
I'm with you on the weight, MrP, this was a conversation with a guy at work. He's doing a Brand X off roader, and from all appearances seems to be on a mission to make this thing as heavy as possible. I had never seen a set in solid steel, so I told him I'd ask.
[Re: Thumperdart]
#2095844
06/21/16 08:25 PM
06/21/16 08:25 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
My Calvert springs came w/an aluminum bushing but didn't notice a sleeve.............. Mine have a steel sleeve that the bolt goes through and the belcranks pivot on. For an off road rig I'd probably do yellow brass instead of steel.
