Leaf spring bushings #2095378
06/21/16 12:40 AM
06/21/16 12:40 AM
pennsylvania
poboyengineering Offline OP
pennsylvania
Most are aluminum with a steel sleeve. Is there any reason they can't be made in solid steel?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Leaf spring bushings [Re: poboyengineering] #2095396
06/21/16 12:57 AM
06/21/16 12:57 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
No
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Leaf spring bushings [Re: poboyengineering] #2095407
06/21/16 01:08 AM
06/21/16 01:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why carry the added weight
wave
Re: Leaf spring bushings [Re: poboyengineering] #2095629
06/21/16 01:42 PM
06/21/16 01:42 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
If you make them out of steel i would put some grease on the spring eye bolt.They could be a pia to remove if rust sets in. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: Leaf spring bushings [Re: poboyengineering] #2095781
06/21/16 06:16 PM
06/21/16 06:16 PM
pennsylvania
pennsylvania
I'm with you on the weight, MrP, this was a conversation with a guy at work. He's doing a Brand X off roader, and from all appearances seems to be on a mission to make this thing as heavy as possible.
I had never seen a set in solid steel, so I told him I'd ask.
Re: Leaf spring bushings [Re: poboyengineering] #2095785
06/21/16 06:18 PM
06/21/16 06:18 PM
fullmetaljacket Offline
Solid aluminum with a steel sleeve is all that have been out there so far.
Re: Leaf spring bushings [Re: fullmetaljacket] #2095839
06/21/16 08:13 PM
06/21/16 08:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My Calvert springs came w/an aluminum bushing but didn't notice a sleeve.............. work
Re: Leaf spring bushings [Re: Thumperdart] #2095844
06/21/16 08:25 PM
06/21/16 08:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine have a steel sleeve that the bolt goes through and the belcranks pivot on.
For an off road rig I'd probably do yellow brass instead of steel.
Re: Leaf spring bushings [Re: Thumperdart] #2095854
06/21/16 08:42 PM
06/21/16 08:42 PM
it has to have a steel sleeve and you must have missed it or else it will eat itself out of housing and home.
Re: Leaf spring bushings [Re: fullmetaljacket] #2096027
06/22/16 02:12 AM
06/22/16 02:12 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe brain fade cos I don't remember sleeves being there and it`s been a while since I had the leafs completely out....... work
Re: Leaf spring bushings [Re: fullmetaljacket] #2096080
06/22/16 09:08 AM
06/22/16 09:08 AM
moparx Offline
moparx  Offline
and if it doesn't do that, once galvanic corrosion sets in, the bolt will weld itself to the bushing, making a real treat to remove. i have learned many new words over the years dealing with this issue. it's not so or too bad when there is more than .020-.030 clearance between the bolt shank and the bushing hole, but that just accelerates the hole wear. when you get the slop out of the bushing [as it should be to be effective], that allows the two dissimilar metals to corrode together locking them solid. then the fun begins. and even using a sleeve, anti-seize or high pressure grease is a must for best performance.
beer
