Base line timing for low deck stroker
#2095487
06/21/16 08:55 AM
06/21/16 08:55 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
I have a friend who bought a car that was freshly built, and then the owner decided not to race it. He took it to a local 1/8 mile track and it's best run was in the high 6.9s. Low deck stroker? with Indy aluminum heads and 590 MP cam. I did a quick compression test and came up with 185-190 on the gauge. For a baseline, I set it at 36 degrees. A test hit was made and he swears it is much stronger. What do you guys run. I know nothing of the engine for sure, other than the cranking pressure.
Re: Base line timing for low deck stroker
[Re: Hemi ragtop]
#2095646
06/21/16 02:16 PM
06/21/16 02:16 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Depends on the efficiency of the over all package and particularly the head is as to how much timing it will want. The more efficient the less over all timing it will need to compete the burn. The less efficient it is the more timing it will need. There is no Magic number really way to many variables. But start safe and advance as needed. Many -1 head combos seem to end up in the mid 30's total fwiw some will need more some will want less. Remember timing will affect AFR's as well, the more it is advanced the leaner things will become generally speaking.
[Re: Hemi ragtop]
#2096168
06/22/16 11:47 AM
06/22/16 11:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a friend who bought a car that was freshly built, and then the owner decided not to race it. He took it to a local 1/8 mile track and it's best run was in the high 6.9s. Low deck stroker? with Indy aluminum heads and 590 MP cam. I did a quick compression test and came up with 185-190 on the gauge. For a baseline, I set it at 36 degrees. A test hit was made and he swears it is much stronger. What do you guys run. I know nothing of the engine for sure, other than the cranking pressure. The engine will talk to you... you went up to 36 and it liked it.. try more.... BUT watch the plugs... the ground strap should show color in the middle of the bend... and make sure your not going lean on fuel
