Have any of you guys come across this? #2094289
06/19/16 03:22 AM
06/19/16 03:22 AM
Marysville, WA
77ProStreet Offline OP
Marysville, WA
I have an 81 W150 and when you turn on the wipers, no matter what speed you put them on, its dreadfully slow. Do you think this is a problem with the delay, since it doesn't delay or the motor?
Re: Have any of you guys come across this? [Re: 77ProStreet] #2094570
06/19/16 07:36 PM
06/19/16 07:36 PM
ohio
mttaff Offline
mttaff  Offline
ohio
Check your grounds. Probably help to actually add a ground.
Re: Have any of you guys come across this? [Re: mttaff] #2094650
06/19/16 10:47 PM
06/19/16 10:47 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Have any of you guys come across this? [Re: 77ProStreet] #2094680
06/19/16 11:25 PM
06/19/16 11:25 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yeah ^, and if that doesn't help, you probably need to rebuild or replace the wiper motor...
Re: Have any of you guys come across this? [Re: 77ProStreet] #2095084
06/20/16 04:37 PM
06/20/16 04:37 PM
ky.
K
kenworth_goose Offline
K
ky.
Add a ground wire. This happens to almost all of the dodge trucks I've owned.
Re: Have any of you guys come across this? [Re: 77ProStreet] #2096496
06/22/16 11:35 PM
06/22/16 11:35 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
wiper pivots corrode and slow the whole deal down, until the plastic retainer cups break and they stop.
try pb blaster on the pivots, you may need to pull it apart and soak them and add a grease fitting.
Re: Have any of you guys come across this? [Re: sthemi] #2096768
06/23/16 02:15 PM
06/23/16 02:15 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
In addition to fixing whatever the issue is, there is one other trick that really helps the wipers in these trucks. If you go one size shorter than stock on the wiper blades it makes a huge difference in performance. They move much faster.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
