Re: How much timing chain slop allowed with roller cam
[Re: Hemi_Joel]
#2093930
06/18/16 01:53 PM
06/18/16 01:53 PM
RapidRobert
I have a Rollmaster set (uninstalled). I'd heard good regarding it. made in Australia iirc
[Re: Thumperdart]
#2094284
06/19/16 02:44 AM
06/19/16 02:44 AM
Posts: 4,457 Washington
madscientist
Washington
I know of 1000 hp cars w/chains.........I saw some used gear drives for sale so may grab one myself soon cos NOTHING sounds meaner than a gear drive and of course perfect timing doesn't hurt.......... If you can hear the gear drive it's junk If you heard my engine run you would not know it has a GD.
[Re: Hemi_Joel]
#2094327
06/19/16 10:42 AM
06/19/16 10:42 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have a Rollmaster set (uninstalled). I'd heard good regarding it. made in Australia iirc This is top quality stuff!!
[Re: madscientist]
#2094373
06/19/16 12:25 PM
06/19/16 12:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know of 1000 hp cars w/chains.........I saw some used gear drives for sale so may grab one myself soon cos NOTHING sounds meaner than a gear drive and of course perfect timing doesn't hurt.......... If you can hear the gear drive it's junk If you heard my engine run you would not know it has a GD. Same here.. it seems the double idler gear drives are noisey ... you cant hear mine even if it had the best muffs on it... I have it apart right now and it looks like new... about 8-10 years old.... the KB unit is a single idler
[Re: Stanton]
#2094391
06/19/16 01:04 PM
06/19/16 01:04 PM
MR_P_BODY
I don't think there is any adjustment in double rollers so they're probably made a tad loose so they'd still fit after a line hone. The one's I've seen also have very coarse gears compared to the single idler KB unit I had. True... the link bar between the 2 idlers is a fixed point and I'm sure they are a bit sloppy on the mesh..to set a KB you use a piece of paper as the gap
[Re: Hemi_Joel]
#2095080
06/20/16 04:23 PM
06/20/16 04:23 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Is the Milodon gear drive as good and as quiet as the KB? It's cheaper.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2095106
06/20/16 05:19 PM
06/20/16 05:19 PM
MR_P_BODY
Is the Milodon gear drive as good and as quiet as the KB? It's cheaper. If its a single idler that has a adjustment on it(and I think it is) then yes its quiet.... you want a single gear... any dual gear the link bar is pre set and can be sloppy(noise) EDIT The dual idlers sound like a blower
[Re: dogdays]
#2095634
06/21/16 01:50 PM
06/21/16 01:50 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Timing chains do not stretch, the pins wear. Eliminating chain wear during the first operation as the chain breaks in would probably extend the life.
R.
The cheaper timing sets have cast gears which also wear & add to chain slop.
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2096296
06/22/16 04:19 PM
06/22/16 04:19 PM
dogdays
The Keith Black gear drive is not available for the early Hemi/LA. The Milodon is a single gear, installs under the timing cover. Milodon has been making them for many engines for at least 40 years. It's not a two gear setup. BTW, two gear setups can usually be bought noisy or quiet. Noisy ones have straight cut teeth. I believe after the first 50 miles the whine would be obnoxious.
I'm sure tooth wear is a factor on chains but not in the first few thousand miles. Also tooth wear tends to put a hook in the flank of the tooth, doesn't do much to the bottom or the opposite side of the tooth, which is where the slop would come from. The Rollmaster high dollar setup has billet gears, so tooth wear should be negligible as long as they picked the material wisely.
There is a third timing alternative, the timing belt that's available from HotHemiHeads.com but it's in the four digit price range.
R.
