Brain fade couple basic questions need answer
#2093991
06/18/16 03:42 PM
06/18/16 03:42 PM
Posts: 2,345 west palm beach, florida
modelmakerinc
One: are small block and Big block 727 converters interchangeable? yes or why not
Two: is the 400ci internally externally balanced? Do you need a special flex plate like a 360.
Basic questions but I can think of the correct answer and not in the position to research. Thanks
Re: Brain fade couple basic questions need answer
[Re: modelmakerinc]
#2094013
06/18/16 04:42 PM
06/18/16 04:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I can answer part of it.. the conv for a SB and a BB 727 are the same... when it comes to mounting it... it will slide in just like the other and it bolts on to the flex just like the other... normally the stall will be different but thats all... as to the balance... I dont know.. I never ran a 400 block
[Re: MR_P_BODY]
#2094034
06/18/16 05:34 PM
06/18/16 05:34 PM
dartman366
Mt. Vernon, Ohio
According to B@M they are external balance.
[Re: dartman366]
#2094056
06/18/16 06:32 PM
06/18/16 06:32 PM
MR_P_BODY
According to B@M they are external balance. IF he is running a external balanced conv he can knock the weight off... if if he needs to add weight MP use to sell the weights and the location to where it went.. but I dont know if they do any more or not
[Re: modelmakerinc]
#2094060
06/18/16 06:45 PM
06/18/16 06:45 PM
Posts: 561 USA
B3RE
USA
Basic questions but I can think of the correct answer and not in the position to research. Thanks As mentioned, converters yes. A cast crank 400 is externally balanced, and has it's own imbalance. Meaning, it will need a special 400 imbalance flexplate, or a torque converter with weights for a 400. A 360 or 440 will not be the same.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: modelmakerinc]
#2094094
06/18/16 07:27 PM
06/18/16 07:27 PM
Posts: 561 USA
B3RE
USA
It's available from B&M. Save yourself a lot of grief and pick up the plate for about $80 and call it a day.
Mike Beachel
[Re: modelmakerinc]
#2094097
06/18/16 07:33 PM
06/18/16 07:33 PM
dartman366
Mt. Vernon, Ohio
B@M has a flex for use with neutral balance converters for the 400's
[Re: B3RE]
#2094109
06/18/16 08:11 PM
06/18/16 08:11 PM
Posts: 25,901 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A cast crank 400 is externally balanced, and has it's own imbalance. Actually, all cast crank BB's (383, 400, 440) use the same external balance weight. The B&M #10237 covers them all.
[Re: John_Kunkel]
#2094130
06/18/16 09:07 PM
06/18/16 09:07 PM
Posts: 561 USA
B3RE
USA
A cast crank 400 is externally balanced, and has it's own imbalance. Actually, all cast crank BB's (383, 400, 440) use the same external balance weight. The B&M #10237 covers them all. My mistake John. You are correct.
Mike Beachel
