Early b body shocks #2093415
06/17/16 10:38 AM
06/17/16 10:38 AM
6T4 Polara Offline OP
Street cars 62-65 B bodies what are you using and are you happy.
thanks
Re: Early b body shocks [Re: 6T4 Polara] #2093469
06/17/16 12:42 PM
06/17/16 12:42 PM
No actual exp but KYB seems to get good reviews here on occaision
Re: Early b body shocks [Re: RapidRobert] #2093491
06/17/16 01:35 PM
06/17/16 01:35 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I put KYB shocks on my '64 Polara and I am using the KYB on the '87 Ram daily driver. Good gas charged shocks and you can get them on www.rockauto.com
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Early b body shocks [Re: Polarapete] #2093561
06/17/16 04:05 PM
06/17/16 04:05 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
My KYB's are on a 70...All front suspension and vehicle weight are nearly the same as the 64. About 15K on them...the gas shocks seemed to improve the handling some as I don't really notice much rollover. twocents
...FAFO...
Re: Early b body shocks [Re: skicker] #2093683
06/17/16 08:17 PM
06/17/16 08:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I put Monroes's all the way around on my '63 Dodge. The ride was great! I did replace the fronts only because I wanted 90/10 shock to get the front end up and keep it there for weight transfer. Fronts are now Competition Engineering.
'63 Dodge 330
11.19 @ 121 mph
Re: Early b body shocks [Re: 6T4 Polara] #2093691
06/17/16 08:32 PM
06/17/16 08:32 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
cheap monroe's on my '65 coronet. seem to do everything i want.
Re: Early b body shocks [Re: 6T4 Polara] #2093736
06/17/16 10:17 PM
06/17/16 10:17 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I have summit adjustables on my 65 coronet. They have been on there for 16 years with no problems.
Re: Early b body shocks [Re: 6T4 Polara] #2093788
06/18/16 12:51 AM
06/18/16 12:51 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks
track or street/ soft or firm ? need more info wink
Re: Early b body shocks [Re: 6T4 Polara] #2093965
06/18/16 02:57 PM
06/18/16 02:57 PM
Seymour,IN.
HoosierGTX Offline
HoosierGTX  Offline
Seymour,IN.
KYB all around on my 65 Coronet
Re: Early b body shocks [Re: 6T4 Polara] #2094179
06/18/16 11:04 PM
06/18/16 11:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ran the standard Monroes on the '63 & '64; nice ride, no issues. Neither car was used for fast cornering, though.
Re: Early b body shocks [Re: 6T4 Polara] #2094221
06/19/16 12:25 AM
06/19/16 12:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On my 63 Sport Fury street/strip car I run the Comp Engineering 90/10's up front and the MP long shocks in the rear to work with the SS springs. Car drives and rides great. Ron
Re: Early b body shocks [Re: 383man] #2094388
06/19/16 12:57 PM
06/19/16 12:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used to run Lakewood 90/10's on the front but for my new street car setup I'm running KYB gas units. For the rear I use Rancho adjustable shocks set on 2 for the street and set them on 7 for the track.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Early b body shocks [Re: 6T4 Polara] #2094619
06/19/16 09:45 PM
06/19/16 09:45 PM
fullmetaljacket Offline
Calvert 90/10 non adjustable shocks.
Viking double adjustable rears.
Rock and roll baby.
Re: Early b body shocks [Re: fullmetaljacket] #2096628
06/23/16 08:07 AM
06/23/16 08:07 AM
Friend put C&E shocks all around will report on the ride.
