How much timing chain slop allowed with roller cam #2093283
06/17/16 12:45 AM
06/17/16 12:45 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
I put a COMP Cams Hi-Tech Roller Race Timing Set 3103 in my early 392 Hemi with a .700 lift roller cam. After about a dozen or so dyno pulls, the chain has 5/8" slop, measured by pushing and pulling the chain each way. It seems to me that it is a lot of slop.
What do you guys think? Should I re-use it or get something new and better?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093309
06/17/16 01:43 AM
06/17/16 01:43 AM
what I would do is (1) turn the dampener to 15 ATDC (2) then back it up exactly/smoothly to TDC (3) then have a helper watch the dist rotor (4) have him confirm the springs have retracted the rotor all the way & wouldn't hurt to have him hold it lightly in that position to take out the intergear/to dist tang slot slop out of the picture (5) with breaker bar/1&1/4 socket/cheater bar for leverage to move it smoothly, move the dampener CW till you helper yells that he felt the rotor JUST move & note how many degrees the dampener moved
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093328
06/17/16 02:29 AM
06/17/16 02:29 AM
Washington
madscientist Offline
Washington
Was it that loose when it was assembled?
That is what I call junk.
Sorry to be blunt but that is a fact.
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093401
06/17/16 10:16 AM
06/17/16 10:16 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I would call comp and ask if this normal, then I would check the cam centerline and adjust.
Joe
Without Data, you’re just another guy with an opinion.
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093414
06/17/16 10:34 AM
06/17/16 10:34 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sounds like a line hone took out a fair bit. What's the availability of an oversize set? I think the RollMaster site has a guide that tells you what o/s set you'd need based on the amount of slop. Thats if an o/s set is available !! If not, what are you going to do ... gear drive maybe !!
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093428
06/17/16 11:04 AM
06/17/16 11:04 AM
pennsylvania
poboyengineering Offline
pennsylvania
Too much align boring will cause the gear drive to not have enough lash between the teeth. Saw a guy eat a really expensive motor that way.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093436
06/17/16 11:24 AM
06/17/16 11:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Joel... thats a LOT already and its new... if you can..
see if they make a gear drive for it.. that will give you
adjustment on the idler gear so you can take that play out
of it.... was that one short already for a line honed block
if its stock see about a short chain set up
wave
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093468
06/17/16 12:42 PM
06/17/16 12:42 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
That much slop will definitely affect your timing events. Do yourself a favor, before installing any new timing chain, soak it in synthetic gear oil on its side for a few days. Nothing protects a chain and reduces initial wear as good as that stuff does.
I've experimented with all different types of oil on my chain saw chains, and nothing even comes close to keeping a chain from wearing like it does. I started using it on my new motor's timing sets about 10 years ago, and chain stretch/wear seems to be a thing of the past. Before that, they all stretched significantly. Strange, but true.
Re: How much timing chain slop allowed with roller cam [Re: jbc426] #2093477
06/17/16 01:02 PM
06/17/16 01:02 PM
[quote6] Strange, but true. [/quote] Not strange at all, solid gold info, much appreciated!
Re: How much timing chain slop allowed with roller cam [Re: jbc426] #2093516
06/17/16 02:38 PM
06/17/16 02:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Better yet, cook it in syn. oil on an open camping burner THEN it`s impregnated into the chain.............Pettis did this on every build w/a chain w/excellent results..........
Re: How much timing chain slop allowed with roller cam [Re: Thumperdart] #2093543
06/17/16 03:23 PM
06/17/16 03:23 PM
Jamie McGrath Offline
Thanks for the info! Where is the Thanks Button when you need it..
Re: How much timing chain slop allowed with roller cam [Re: Jamie McGrath] #2093553
06/17/16 03:47 PM
06/17/16 03:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It really works man............
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093620
06/17/16 06:05 PM
06/17/16 06:05 PM
Minnesota
Minnesota
Thanks for the info. THis chain had no slop when I installed it. Now 5/8" after minimal use. I need to find the best chain I can buy and cook it in synthetic oil.
This is the same timing set as a small block Mopar. What is the best?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093632
06/17/16 06:29 PM
06/17/16 06:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093636
06/17/16 06:35 PM
06/17/16 06:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since its a SB I would change over to a gear drive...
I will be changing my 416 over to my spare gear drive...
also if you want you can use the MP tensioner set up which
I have on the 416 right now... I had the front off the other
day and after the initial wear from a double roller chain it
looks great... on the double roller chain it has the 3 walls
(small surface area) but as soon as it starts riding on the
rollers it last great... mine has 700 miles on it now... if
I wanted to leave it on I could/would and have no issue doing
it... but I like gear drives... my gear drive is the KB that
MP sells... not cheap but well worth the cost
wave
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093637
06/17/16 06:48 PM
06/17/16 06:48 PM
Minnesota
Minnesota
Mr.P, do you have a part # for the KB gear drive?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093648
06/17/16 07:13 PM
06/17/16 07:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the MP #.. not sure if they still sell it but
check with Mancini or one of the other MP places
P5249758... for use with pump eccentric
P5249956... with out fuel pump eccentric...
I bought mine about 8 years back when I was working
and got 25% off... if you get one the drivers side
lifter end hole(at the front) needs to be drilled and
tapped or a plug pushed in.... otherwise your oil pressure
will be super low(half that hole will be open).... the
tensioner one is P5007709..you can get that at Mancini or
some other places... I believe there are other brands for this
one also
EDIT
The gear drive needs 1 hole drilled and taped if I
remember right... plus it fits under the stock SB LA
cover
wave
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093657
06/17/16 07:37 PM
06/17/16 07:37 PM
Washington
Washington
Or use a Milodon gear drive. Look on th web you can find them used. They don't wear out.
You will never have to worry about cam timing agin. And you won't have to run stupid P/V clearance.
I'd bet a good bit your cam was retarding 6-8* or more under load.
Timing chains are junk. You can use a gear drive or a belt, but why in the year 2016 guys are still running chains is beyond me.
Re: How much timing chain slop allowed with roller cam [Re: Thumperdart] #2093881
06/18/16 11:15 AM
06/18/16 11:15 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Huh... learn something new every day.
72 Plymouth Roadrunner 11.08@123.25
Re: How much timing chain slop allowed with roller cam [Re: Roughbird72] #2093928
06/18/16 01:46 PM
06/18/16 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know of 1000 hp cars w/chains.........I saw some used gear drives for sale so may grab one myself soon cos NOTHING sounds meaner than a gear drive and of course perfect timing doesn't hurt..........
