Re: air packing
[Re: fullmetaljacket]
#2093437
06/17/16 11:26 AM
06/17/16 11:26 AM
Posts: 20,166 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Bernoulli principle
Not sure if this is what you are talking about.
https://en.wikipedia.org/wiki/Talk:Venturi_effect
Re: air packing
#2093438
06/17/16 11:28 AM
06/17/16 11:28 AM
Posts: 20,166 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Oh well I tried to copy and paste but I have a race to get to.
Re: air packing
#2093453
06/17/16 12:13 PM
06/17/16 12:13 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Not enough info for an accurate answer. If air is moving (A: what is making it move) velocity will go up (to a point based on "A") if the orifice is decreased in size, while pressure will rise as it approaches the minimum area.
Re: air packing
#2093858
06/18/16 10:28 AM
06/18/16 10:28 AM
fullmetaljacket
Here's my boys Poison Dart with the ever so popular Hurst Hemi scoop and it might not work as good on it because of the short field in the "Facility" But I will give it a try.
Re: air packing
[Re: FastmOp]
#2093960
06/18/16 02:44 PM
06/18/16 02:44 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I lost et blocking the grill in back 2 back tests but I believe it was due to the "pocket" since I attached it inboard but if you can mount it flush it may work better............
Re: air packing
#2094077
06/18/16 07:04 PM
06/18/16 07:04 PM
Thumperdart
State of confusion
Lets first call the vast inside area of my outdated scoop attached below as the "Facility" I'm just thinking of a poor mans super charger effect utilizing the scoop by creating a series of dams with various foils or spoilers inside the "facility" that will probably only work at speed. I have a few drawings that will take time to develop into actual dams that will then be temporarily affixed inside and do some testing Motown Missile style. If you shoot me your cell # I`ll send a pick of my air dams that I`ve tested and really work along w/a sealed air pan and pressure release holes at the rear of my 6-pack scoop..............
