Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2093930
06/18/16 01:53 PM
06/18/16 01:53 PM
What is the best?
I have a Rollmaster set (uninstalled). I'd heard good regarding it. made in Australia iirc
Re: How much timing chain slop allowed with roller cam [Re: Thumperdart] #2094284
06/19/16 02:44 AM
06/19/16 02:44 AM
Washington
madscientist Offline
Washington
Originally Posted By Thumperdart
I know of 1000 hp cars w/chains.........I saw some used gear drives for sale so may grab one myself soon cos NOTHING sounds meaner than a gear drive and of course perfect timing doesn't hurt..........
If you can hear the gear drive it's junk
If you heard my engine run you would not know it has a GD.
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2094327
06/19/16 10:42 AM
06/19/16 10:42 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What is the best?
This is top quality stuff!!
Re: How much timing chain slop allowed with roller cam [Re: madscientist] #2094373
06/19/16 12:25 PM
06/19/16 12:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here.. it seems the double idler gear drives are
noisey ... you cant hear mine even if it had the best muffs
on it... I have it apart right now and it looks like new...
about 8-10 years old.... the KB unit is a single idler
wave
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2094377
06/19/16 12:33 PM
06/19/16 12:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't think there is any adjustment in double rollers so they're probably made a tad loose so they'd still fit after a line hone. The one's I've seen also have very coarse gears compared to the single idler KB unit I had.
Re: How much timing chain slop allowed with roller cam [Re: Stanton] #2094391
06/19/16 01:04 PM
06/19/16 01:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
True... the link bar between the 2 idlers is a fixed point
and I'm sure they are a bit sloppy on the mesh..to set a
KB you use a piece of paper as the gap
wave
Re: How much timing chain slop allowed with roller cam [Re: MR_P_BODY] #2095079
06/20/16 04:21 PM
06/20/16 04:21 PM
dogdays Offline
dogdays  Offline
The Milodon gear drive runs about $450 and is supposed to adjust to any amount of line boring/honing.
The Rollmaster timing set with billet sprockets and iwis chain is the best chain setup. It is around a third of the cost of the gear drive.
Timing chains do not stretch, the pins wear. Eliminating chain wear during the first operation as the chain breaks in would probably extend the life.
R.
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2095080
06/20/16 04:23 PM
06/20/16 04:23 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Is the Milodon gear drive as good and as quiet as the KB? It's cheaper.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How much timing chain slop allowed with roller cam [Re: Hemi_Joel] #2095106
06/20/16 05:19 PM
06/20/16 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its a single idler that has a adjustment on it(and
I think it is) then yes its quiet.... you want a single
gear... any dual gear the link bar is pre set and can
be sloppy(noise)
EDIT
The dual idlers sound like a blower
wave
Re: How much timing chain slop allowed with roller cam [Re: dogdays] #2095634
06/21/16 01:50 PM
06/21/16 01:50 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
R.
The cheaper timing sets have cast gears which also wear & add to chain slop.
72 Plymouth Roadrunner 11.08@123.25
Re: How much timing chain slop allowed with roller cam [Re: Roughbird72] #2096296
06/22/16 04:19 PM
06/22/16 04:19 PM
dogdays Offline
dogdays  Offline
The Keith Black gear drive is not available for the early Hemi/LA.
The Milodon is a single gear, installs under the timing cover. Milodon has been making them for many engines for at least 40 years. It's not a two gear setup.
BTW, two gear setups can usually be bought noisy or quiet. Noisy ones have straight cut teeth. I believe after the first 50 miles the whine would be obnoxious.
I'm sure tooth wear is a factor on chains but not in the first few thousand miles. Also tooth wear tends to put a hook in the flank of the tooth, doesn't do much to the bottom or the opposite side of the tooth, which is where the slop would come from. The Rollmaster high dollar setup has billet gears, so tooth wear should be negligible as long as they picked the material wisely.
There is a third timing alternative, the timing belt that's available from HotHemiHeads.com but it's in the four digit price range.
R.
