Oil Pan R&R 2004 Dodge Durango ? #2093089
06/16/16 05:44 PM
06/16/16 05:44 PM
Holly/MI
Dean_Kuzluzski Offline OP
Holly/MI
Oil pan is rusting out on our old 2004 Doge DooRango. Cheap to buy but a hassle to change. Looking for tips to ease the pain. Looks like......
Back off T-bar tension
Drop center tiebar
Unbolt frt diff & drop down
Undo 1/2-shafts??
Anything else?
Thanks in advance....
Re: Oil Pan R&R 2004 Dodge Durango ? [Re: Dean_Kuzluzski] #2093116
06/16/16 06:52 PM
06/16/16 06:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not any help but my 06 Ram oil pan is rusting too. Looks like I will have to change it in the near future.
Re: Oil Pan R&R 2004 Dodge Durango ? [Re: Dean_Kuzluzski] #2093119
06/16/16 06:58 PM
06/16/16 06:58 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
wink
Attached PDF document
oilpan.pdf (116 downloads)
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Oil Pan R&R 2004 Dodge Durango ? [Re: Dean_Kuzluzski] #2093189
06/16/16 09:25 PM
06/16/16 09:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I know 04 is different, but I did do a couple of 99 ish durangos with just dropping diff a bit, probably removed halfshafts, but saw no need to fiddle with torsion adjustment on them.
Re: Oil Pan R&R 2004 Dodge Durango ? [Re: Dean_Kuzluzski] #2093190
06/16/16 09:27 PM
06/16/16 09:27 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
We took the pan off my dad's old '96 Dakota 3.9. Had to jack the motor up AND remove the bolts on the steering rack so that it could drop down.
Re: Oil Pan R&R 2004 Dodge Durango ? [Re: Dean_Kuzluzski] #2093373
06/17/16 08:37 AM
06/17/16 08:37 AM
Holly/MI
Holly/MI
Ok, thanks everyone!
The only reason I mentioned backing off the torsion bar tension is because of pulling that center tie bar. Those tend to keep the frame from twisting. Maybe, if it's supported frame on jackstands it'll be a non-issue.
Re: Oil Pan R&R 2004 Dodge Durango ? [Re: Dean_Kuzluzski] #2094238
06/19/16 12:43 AM
06/19/16 12:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The 4x4 ones were not fun. Some years had the brackets that also bolted under the eng mounts and that made for more of a pain. Its not a fun job. Ron
