Re: tips on setting points / dwell [Re: fuelishnsilly] #2093020
06/16/16 03:29 PM
06/16/16 03:29 PM
W
Wagonman1967 Offline
W
FWIW I use the original points dist and an Old MSD 6A. The load IE current to the points is reduced and they are only used to trigger the box. They last along time and dont burn or pit. I also keep a harness and the ballast resistor in the trunk if the MSD fails. Never ever had a problem and was a swapmeet find. Did I say I am Cheep?
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: tips on setting points / dwell [Re: fuelishnsilly] #2093135
06/16/16 07:27 PM
06/16/16 07:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Take dist out and set in the box the electronic dist came in. Many hours wasted on that pos.
Re: tips on setting points / dwell [Re: fuelishnsilly] #2093175
06/16/16 08:56 PM
06/16/16 08:56 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
You need to remember that changing the point gap changes the ignition timing.
