mopar intake p4876129 #2092998
06/16/16 02:35 PM
06/16/16 02:35 PM
CA
MorePower Offline OP
CA
Does anybody know if mopar performance intake manifold p4876129 is for use with stock port heads or max wedge I have only found conflicting information on this and would like to know for sure.
Re: mopar intake p4876129 [Re: MorePower] #2093332
06/17/16 02:33 AM
06/17/16 02:33 AM
I'd call Mancini or jegs & see if a tech will go get one & do a quick measure of a port opening
Re: mopar intake p4876129 [Re: MorePower] #2093472
06/17/16 12:54 PM
06/17/16 12:54 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Found this.
Re: mopar intake p4876129 [Re: MorePower] #2093631
06/17/16 06:28 PM
06/17/16 06:28 PM
CA
CA
according to that it'd be max wedge. I did see that but that was part of the conflict. I was hoping someone would have used this manifold and know exactly.
Re: mopar intake p4876129 [Re: MorePower] #2093767
06/17/16 11:47 PM
06/17/16 11:47 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Stage VI Max Wedge...not the same as factory "max wedge".
Re: mopar intake p4876129 [Re: Tommy D] #2093780
06/18/16 12:18 AM
06/18/16 12:18 AM
we're glad you shared that critical piece of info with us, I never woulda guessed! (that they are different)
Re: mopar intake p4876129 [Re: MorePower] #2093852
06/18/16 10:22 AM
06/18/16 10:22 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I have one of those intakes. You need the stage VI heads to bolt it on.
Re: mopar intake p4876129 [Re: Dean_Kuzluzski] #2094096
06/18/16 07:30 PM
06/18/16 07:30 PM
the intake port height is higher on them correct?
