Re: Ported Indy Intakes
[Re: WHITEDART]
#2092657
06/15/16 08:21 PM
06/15/16 08:21 PM
Posts: 3,456 Out West
408strokerdart
Out West
245cc...?????? is a small block head... Big Block 440-1 heads.
[Re: HardcoreB]
#2093508
06/17/16 02:07 PM
06/17/16 02:07 PM
408strokerdart
Out West
ill try to find an old pic of one I did that worked well correcting distribution without removing length from the runner dividers. if you look straight down the throttle barrels trajectory, you'll see why they bias fuel towards the outer runners...So, I undercut the divider bottoms with about a 3/4" radius then radiused the inner walls to a near point on the outer runner edges...especially on top...never knife edge the leading edges. If no one posts one done 'correctly' here look at the general practices that you will find posted on YBullet in the engine section. Another thing that can be done is give it more plenum via spacer...that will help distribution as well....other than this it is a good manifold. Yes, I would love to see some pictures of one done right. The port dividers were my biggest question. They are not right the way they are now....that's for sure.
[Re: AndyF]
#2095091
06/20/16 04:43 PM
06/20/16 04:43 PM
408strokerdart
Out West
I think the Super Victor is a better intake to start with. That looks 1000% better than what I currently have. I guess I will take some before and after pics of mine. Time to make a pile of chips.
[Re: 408strokerdart]
#2095126
06/20/16 05:58 PM
06/20/16 05:58 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I think the Super Victor is a better intake to start with. That looks 1000% better than what I currently have. I guess I will take some before and after pics of mine. Time to make a pile of chips. It looks that good b/c Wilson has already ported that one.
[Re: an8sec70cuda]
#2095213
06/20/16 08:25 PM
06/20/16 08:25 PM
Posts: 1,030 ohio
67mprfan
ohio
I think the Super Victor is a better intake to start with. That looks 1000% better than what I currently have. I guess I will take some before and after pics of mine. Time to make a pile of chips. It looks that good b/c Wilson has already ported that one. I thought the Victor bottom end didn't compare to the Indy
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
#2096091
06/22/16 09:49 AM
06/22/16 09:49 AM
Posts: 6,295 U.S.
moparniac
U.S.
On my 440-1 CNC 345 4500 intake that i ported out it ended up kinda looking like the intake Andy posted as all squared up in there in the plenum and not like the stock Indy with that extra aluminum cloverleaf look. I also took a little more off in the outer 4 runners in the plenum are to help make the plugs look better and more equal, still wanna take a little more off there yet. I only have a couple basic pics but can try in get more stuff is at my garage. I did bring the dividers back some also.
Mopar Performance
