R3 blocks and motor mounts
#2090549
06/12/16 11:38 AM
06/12/16 11:38 AM
Posts: 611 Muncie
Racebuddy
Muncie
my 340 block, 904 trans, in a 67 Satellite fit perfectly with these TTI headers. Using the same motor mounts and headers, it seems that the drivers side header will not bolt up. The torsion bar seems to be really in the way.
Anyone have knowledge on if the motor mount needs corrected or ???
What year or engine mount is needed?
Thanks fellas
Re: R3 blocks and motor mounts
[Re: R3DART]
#2091320
06/13/16 06:14 PM
06/13/16 06:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm not sure about the R3, but on the Ritter block I had to make a few small adjustments to the ds header (TTI 1 7/8) Where the cylinder head meets the block, the block is wider than the head, had to tweak a couple tubes there, also the bottom row of head studs interfered in a couple spots. Resulted in keeping the header away from the head just slightly. It was really close to fitting, had I not mocked it up on the engine stand, I would have had a really tough time finding the interference. This was in an a-body. Indy heads on aluminum Ritter block. If a beveled spacer would have fit it could have moved the header out a bit to clear the studs and maybe some of the other issues EDIT Or cut about 7/8 of the way through the tubes at the flange and bow them out and reweld them
[Re: Racebuddy]
#2091477
06/13/16 11:14 PM
06/13/16 11:14 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I did notice that the R1 at least takes the 318 style mounts vs the 360 ones.
68 Barracuda Formula S 340
