4 speed reverse plug #2092188
06/15/16 12:47 AM
06/15/16 12:47 AM
canada
fast414 Offline OP
fast414  Offline OP
canada
Hey Guys ! Just wondering if any body knows what size plug I need to replace the reverse plug/ switch on my Mopar 4 speed.....have a new one coming but in the mean time I just want to plug it off !! Thanks !
Re: 4 speed reverse plug [Re: fast414] #2092207
06/15/16 01:32 AM
06/15/16 01:32 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The terminals on the back-up lite switch are 0.25" tab male, so just use the mating in-line 0.25" tab female connectors, available everywhere. Note there is no polarity to the switch's (2) terminals.
Just my $0.02... wink
Re: 4 speed reverse plug [Re: fast414] #2092209
06/15/16 01:44 AM
06/15/16 01:44 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think he's looking for the thread size on the switch so he can install a brass plug or something.
Re: 4 speed reverse plug [Re: Morty426] #2092214
06/15/16 01:57 AM
06/15/16 01:57 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Probably be better off using the old switch to keep the hole plugged. It's not a pipe thread that you could just thread anything into...needs a seal (as the original switches use) to seal it up and seat against.
Re: 4 speed reverse plug [Re: OzHemi] #2092223
06/15/16 02:39 AM
06/15/16 02:39 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I know but I assume his is broken to the point that it's leaking
Re: 4 speed reverse plug [Re: fast414] #2092277
06/15/16 09:41 AM
06/15/16 09:41 AM
canada
fast414 Offline OP
fast414  Offline OP
canada
Yes it broken n it's leaking
Re: 4 speed reverse plug [Re: fast414] #2092300
06/15/16 10:08 AM
06/15/16 10:08 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
So it's not a pipe thread. Take out the switch and go to the hardware store and see if you can find the shortest bolt in the same thread as possible. It probably does not exist. If it does you'll need an O ring or a brass copper crush washer to seal it.
Too long of a bolt will interfere with the shift mechanism
Re: 4 speed reverse plug [Re: fast414] #2092332
06/15/16 10:58 AM
06/15/16 10:58 AM
canada
fast414 Offline OP
fast414  Offline OP
canada
K thanks !!!
Re: 4 speed reverse plug [Re: fast414] #2092337
06/15/16 11:13 AM
06/15/16 11:13 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
http://www.rockauto.com/en/catalog/plymouth,1967,gtx,7.2l+440cid+v8,1347229,electrical-switch+&+relay,back+up+lamp+switch,4240
Re: 4 speed reverse plug [Re: fast414] #2092466
06/15/16 02:58 PM
06/15/16 02:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IIRC, the switch thread is 9/16"-18....same as #6 AN.
