Re: 4 speed reverse plug
[Re: fast414]
#2092207
06/15/16 01:32 AM
06/15/16 01:32 AM
Posts: 5,447 So Cal
Sinitro
So Cal
The terminals on the back-up lite switch are 0.25" tab male, so just use the mating in-line 0.25" tab female connectors, available everywhere. Note there is no polarity to the switch's (2) terminals. Just my $0.02...
[Re: Morty426]
#2092214
06/15/16 01:57 AM
06/15/16 01:57 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I think he's looking for the thread size on the switch so he can install a brass plug or something.
Probably be better off using the old switch to keep the hole plugged. It's not a pipe thread that you could just thread anything into...needs a seal (as the original switches use) to seal it up and seat against.
[Re: OzHemi]
#2092223
06/15/16 02:39 AM
06/15/16 02:39 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Probably be better off using the old switch to keep the hole plugged. It's not a pipe thread that you could just thread anything into...needs a seal (as the original switches use) to seal it up and seat against. I know but I assume his is broken to the point that it's leaking
[Re: fast414]
#2092337
06/15/16 11:13 AM
06/15/16 11:13 AM
Posts: 5,166 CT
GTX MATT
CT
http://www.rockauto.com/en/catalog/plymouth,1967,gtx,7.2l+440cid+v8,1347229,electrical-switch+&+relay,back+up+lamp+switch,4240
[Re: fast414]
#2092466
06/15/16 02:58 PM
06/15/16 02:58 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
IIRC, the switch thread is 9/16"-18....same as #6 AN.
