426 Hemi dampner hits oil pan? #2092026
06/14/16 08:34 PM
06/14/16 08:34 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
I am mocking-up my 426 Hemi without the rods and pistons but put the crank in with the old bearings and tightened the caps down. The crank turns freely but when I put the dampner on it hits the new Milodan oil pan where it bolts to the timing cover. The pulley's don't line up either, but I don't know if I have the correct ones yet. Anyone run into this issue? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092030
06/14/16 08:56 PM
06/14/16 08:56 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
is the lower timing gear on the crank ?
Re: 426 Hemi dampner hits oil pan? [Re: CSK] #2092044
06/14/16 09:27 PM
06/14/16 09:27 PM
Rhinotruck
Rhinotruck
No. There is no cam in it so I did not install the timing gears. So the are you saying the dampner will rest against the timing gear?
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092045
06/14/16 09:29 PM
06/14/16 09:29 PM
Washington
madscientist Offline
Washington
Yes, that was what he was saying. You need the gear on. The damper butts up against the crank gear.
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092047
06/14/16 09:30 PM
06/14/16 09:30 PM
Hello Jimmy. Is the timing cover on?
Re: 426 Hemi dampner hits oil pan? [Re: RapidRobert] #2092063
06/14/16 09:58 PM
06/14/16 09:58 PM
Rhinotruck
Rhinotruck
Yes the timing cover is on and so is the water pump housing. I never thought about what stops the dampner from bottoming out on the crank, now I know! realcrazy Guess I got to get the dampner puller out, take off the water pump housing and timing cover, and put the gear on... runaway
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092066
06/14/16 10:07 PM
06/14/16 10:07 PM
Rhinotruck
Rhinotruck
What is the diameter and height of the correct single groove crank pulley for a super stock Hemi?
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092153
06/14/16 11:58 PM
06/14/16 11:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Some of these questions are scary !!!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092158
06/15/16 12:03 AM
06/15/16 12:03 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Hey, Hey , stop pulling our legs. Someone with over 31,000 post doesn't know that the timing gear has to go on ? come on. And why is the timing cover and water pump on? painting ?
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092173
06/15/16 12:21 AM
06/15/16 12:21 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You need the gear and the oil slinger on
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092178
06/15/16 12:30 AM
06/15/16 12:30 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Oil slinger is optional. twocents
Re: 426 Hemi dampner hits oil pan? [Re: stumpy] #2092190
06/15/16 12:50 AM
06/15/16 12:50 AM
Rhinotruck
Rhinotruck
I am mocking up the engine to install it in the chassis to make sure everything fits before I disassemble it for the machine work. I have other reasons to do it this way too, just can't talk about it yet. whistling I have never even thought about assembling an engine with no reciprocating assembly in it before, therefore it never dawned on me that I needed to put the crank timing gear on. shruggy
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: rowin4] #2092194
06/15/16 01:01 AM
06/15/16 01:01 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Does the number of moparts posts make or break a person as a great mechanic.
Re: 426 Hemi dampner hits oil pan? [Re: NANKET] #2092196
06/15/16 01:06 AM
06/15/16 01:06 AM
Rhinotruck
Rhinotruck
Exactly. I am not a mechanic and never have been, I am a Mechanical Designer and Mechanical Technician and only play with grease and dirt after hours... biggrin
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092215
06/15/16 01:57 AM
06/15/16 01:57 AM
Jimmy You're doing fine. when the time comes I may have a pulley for you
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092224
06/15/16 02:42 AM
06/15/16 02:42 AM
Are you trying to use a street hemi balancer or a race Hemi or a aftermarket balancer? The pulley are not the same for each application tsk shruggy
Re: 426 Hemi dampner hits oil pan? [Re: Cab_Burge] #2092344
06/15/16 11:30 AM
06/15/16 11:30 AM
Rhinotruck
Rhinotruck
I have the thick balancer.
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092379
06/15/16 12:22 PM
06/15/16 12:22 PM
Rhinotruck
Rhinotruck
Anudder pic... realcrazy
A-Body's RULE!
Re: 426 Hemi dampner hits oil pan? [Re: Rhinodart] #2092387
06/15/16 12:43 PM
06/15/16 12:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The stock 68/69-71 Hemi crank pulley is shorter than a stock B/RB pulley by about .75".
Put your water pump pulley on and pull the dampner out till the V belt grooves line up ,,, this is just mock up , no need to tear it all down to put the crank gear/oil slinger in place wink
Jim there are 2 hemi lower pulleys, it all depends on what water pump pulley you use. Up until ... I think .... sometime in 68 the Hemi used the standard B/RB waterpump pulley and had a very shallow crank pulley ... again "I think" ... that pulley is what the Milodon alum crank pulley is based off ? Then sometime in 68 Chrysler changed to the shallower Hemi only water pump pulley and the crank pulley was made a little deeper.
Re: 426 Hemi dampner hits oil pan? [Re: JohnRR] #2092438
06/15/16 02:09 PM
06/15/16 02:09 PM
Rhinotruck
Rhinotruck
OK, wasn't sure what I had. I bought the water pump pulley that Megaparts sells for 66-68 I believe. It is shorter and doesn't come close to the water pump bolts, so when I pull the dampner back where is should be they will probably line-up. up
A-Body's RULE!
