Main bearings for mopar 4" cast crank? #2091653
06/14/16 10:44 AM
06/14/16 10:44 AM
ohio
dart70 Offline OP
dart70  Offline OP
ohio
Is it necessary to run a narrow or chamfered main bearing on a mopar performance stroker cast crank. Small block 4 inch 360/408 application. I know I have to on the rods but not sure on the mains. Part numbers? Should I use half or full groove?
Re: Main bearings for mopar 4" cast crank? [Re: dart70] #2091790
06/14/16 01:53 PM
06/14/16 01:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I usually just use normal bearings. Also on the rods I have just filed a chamfer on the outside edge when I am working on a really tight budget.
