1970 Swinger Rear Pinion Centered? #2091511
06/14/16 12:29 AM
06/14/16 12:29 AM
Santa Fe, NM USA
spurman Offline OP
spurman  Offline OP
Santa Fe, NM USA
Thinking of getting a rear end set up for my car. Is the rear end pinion centered or offset?
Re: 1970 Swinger Rear Pinion Centered? [Re: spurman] #2091521
06/14/16 12:42 AM
06/14/16 12:42 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Centered.......
Re: 1970 Swinger Rear Pinion Centered? [Re: spurman] #2091532
06/14/16 01:09 AM
06/14/16 01:09 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The pinion is offset 1 3/16" toward the passenger side on all A,B,C and E body Mopars. The engine, transmission and driveshaft tunnel is also offset.
Re: 1970 Swinger Rear Pinion Centered? [Re: DoctorDiff] #2091551
06/14/16 01:35 AM
06/14/16 01:35 AM
CA
crackedback Offline
crackedback  Offline
CA
This^^^^
Depending on what you are building
an 8.75 will have equal length axles
D60 will have the drivers side 1 3/8" long than pass side.
Dr Diff has a really nice calculator on his site.
Re: 1970 Swinger Rear Pinion Centered? [Re: spurman] #2091554
06/14/16 01:44 AM
06/14/16 01:44 AM
Santa Fe, NM USA
spurman Offline OP
spurman  Offline OP
Santa Fe, NM USA
Thanks, I'll have to check his site out.
Re: 1970 Swinger Rear Pinion Centered? [Re: spurman] #2091757
06/14/16 01:06 PM
06/14/16 01:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Many THINK the pinion is centered on an 8.75 because the axles are same length, but not the case. As covered NO Mopar pass car rear comes from the factory with a centered pinion. The motors are moved over to clear steering usually, so the entire driveline follows suit
Re: 1970 Swinger Rear Pinion Centered? [Re: Monte_Smith] #2091828
06/14/16 03:26 PM
06/14/16 03:26 PM
dogdays Offline
dogdays  Offline
Moving the motor over also offsets some of the weight of the driver, steering box and column, etc.
R.
Re: 1970 Swinger Rear Pinion Centered? [Re: spurman] #2091947
06/14/16 06:01 PM
06/14/16 06:01 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Chrysler offset,A and B body start at the front of the engine crank centerline 2" to the passenger side,1-5/8 at the trans tailshaft and 1-3/16 at the pinion centerline.These are + and- measurements since the motor,trans mounts as well as the spring perches have wiggle room.This was as mentioned for steering and pedal room.This is what you deal with for stock and backhalf cars.When building a chassis put everything on centerline
Re: 1970 Swinger Rear Pinion Centered? [Re: spurman] #2092206
06/15/16 01:31 AM
06/15/16 01:31 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
There are some good working fabricated cars out there with the driveline C/L moved over 1" to 2". Just saying.
Re: 1970 Swinger Rear Pinion Centered? [Re: spurman] #2092369
06/15/16 12:04 PM
06/15/16 12:04 PM
Guitar Jones Offline
The driveline in my Scamp is offset 1/2" to the right.
