Re: 1970 Swinger Rear Pinion Centered?
[Re: DoctorDiff]
#2091551
06/14/16 01:35 AM
06/14/16 01:35 AM
Posts: 2,079 CA
crackedback
CA
The pinion is offset 1 3/16" toward the passenger side on all A,B,C and E body Mopars. The engine, transmission and driveshaft tunnel is also offset. This^^^^ Depending on what you are building an 8.75 will have equal length axles D60 will have the drivers side 1 3/8" long than pass side. Dr Diff has a really nice calculator on his site.
[Re: spurman]
#2091757
06/14/16 01:06 PM
06/14/16 01:06 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Many THINK the pinion is centered on an 8.75 because the axles are same length, but not the case. As covered NO Mopar pass car rear comes from the factory with a centered pinion. The motors are moved over to clear steering usually, so the entire driveline follows suit
[Re: spurman]
#2092206
06/15/16 01:31 AM
06/15/16 01:31 AM
Posts: 11,638 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
There are some good working fabricated cars out there with the driveline C/L moved over 1" to 2". Just saying.
[Re: spurman]
#2092369
06/15/16 12:04 PM
06/15/16 12:04 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
The driveline in my Scamp is offset 1/2" to the right.
