Shift Light Problem
#2090908
06/12/16 10:47 PM
06/12/16 10:47 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Hi All, Was looking at an in-car vid of my shifting and see the shift light is turning on way early - set at 6500 and is coming on about 5900 https://www.youtube.com/watch?v=Qa6JaYcXnN0Has anyone else ever noticed this as a problem? Crossing the line it looks like the tach agrees with what the RPMs should be so I'm assuming that the problem is related to the shift light setting (pot/vibration) I was thinking about the MSD LED standalone light, or even the autometer. Any luck with those? Thanks
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Shift Light Problem
[Re: oldiron]
#2091027
06/13/16 02:09 AM
06/13/16 02:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Does the shift light use rpm chips that you plug in... those go bad often EDIT if its a knob type... spin it back and forth a few times.. they get dirty
[Re: MR_P_BODY]
#2091068
06/13/16 08:50 AM
06/13/16 08:50 AM
oldiron
New Hampshire, USA
It is the knob type. I check the setting in the staging lanes before every pass because I've hit it with my helmet several times in the past. This changed the setting to as low as 3500 so I got into the habit of checking. I never did try spinning the knob back and forth. I'll give it a try. Thanks
[Re: Abodyjohn88]
#2091495
06/13/16 11:57 PM
06/13/16 11:57 PM
oldiron
New Hampshire, USA
yes, for the 2-3 and 3-4 shifts I'm probably going by ear (or whats left of my left ear). But with the 3.08 1st gear and 4.56 gears my inconsistency is mainly in the 1-2 shift. So if I can get myself to trigger on the light then maybe I'll be a little more consistent
