I may have to concede defeat.
#2090491
06/12/16 08:41 AM
06/12/16 08:41 AM
Posts: 27,728 places
79powerwagon
places
Well, I cannot find any leak anywhere on my 1996 Suburban's AC system, but it clearly loses its coolant overnight. The dye isn't showing up anywhere, and I've had this thing opened up pretty good!
I don't know what else to do, so I guess I'll have to bite the bullet and take it in somewhere and have it fixed.
Any last minute ideas?
EDIT- Sorry, I thought I was in the General section.
Re: I may have to concede defeat.
[Re: 79powerwagon]
#2090548
06/12/16 11:36 AM
06/12/16 11:36 AM
Guitar Jones
[Re: 79powerwagon]
#2090675
06/12/16 03:19 PM
06/12/16 03:19 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
That's a pretty good sized leak you have there. I agree with a possible evaporator issue. If yours has rear air then you also have to look at the rear a/c components as well. The biggest cause of GM a/c leaks I see at my shop is the compressor. They will leak out of the front seal, which can be hard to detect without removing the clutch assembly. They also are prone to leak out of the center of the compressor where the two halves connect. Be looking for traces of refrigerant oil on hoses and system components. Don't overlook the check ports on both high and low sides. They are a common leak point. Good luck. Freon leaks can be a pain to find sometimes.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 79powerwagon]
#2091061
06/13/16 08:35 AM
06/13/16 08:35 AM
Posts: 8,672 Buford, GA
I_bleed_MOPAR
Buford, GA
Just about every time I had an evaporator leak, I could find the dye in the drain hose. (In case you haven't looked there. ) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: 79powerwagon]
#2091695
06/14/16 11:40 AM
06/14/16 11:40 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Thanks everyone! I'll look again before biting the bullet and having it fixed. The whole system is nice and dry and clean (no oil spots or grime build-up). Even under the compressor (the bottom) is dry and clean. Yes, it has rear air (the whole reason for buying a Suburban in the first place). Very frustrating indeed! I am with you on the rear air. Glad my Durango has it. But around here, rear seat warmers are the big deal. Drove to North Dakota without them in a rental car and never heard the end of that. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 79powerwagon]
#2098126
06/25/16 09:02 PM
06/25/16 09:02 PM
79powerwagon
places
After not being able to locate any leaks, I got another dye set (this time UV) and loaded up the system again. Funny thing is, it stayed cold, I even took my dog to the vet and back this morning and it was nice and frosty in there! It's hot here, too!
So I was a bit hopeful it may have "corrected" itself, but alas, no. I went to get some take out BBQ tonight, and it was not cold at all. So at least I was able to run the system for about an hour and a half with it working. The dye should be well circulated, and when the sun goes down tonight, I'll have another look!
[Re: 79powerwagon]
#2098201
06/25/16 11:43 PM
06/25/16 11:43 PM
79powerwagon
places
You guys were right! The compressor bottom and all around it is glowing with dye! No oil, no nothing, can't see anything without the light. But using the light, it's one big green mess! I checked everywhere else, only found a trace leak in a line that runs to teh rear. A quick look thru youtube found several indicating that problem and the repair for it. Time to go shopping! Thanks again everyone! And thanks for being patient with me posting this in the wrong place!
[Re: 79powerwagon]
#2099449
06/27/16 06:12 PM
06/27/16 06:12 PM
I_bleed_MOPAR
Buford, GA
Dang chivvy guys. Glad you found it. Tim
